[mapserver-dev] AGG dependency
Guillaume Sueur no-reply at neogeo-online.net
Sat Apr 25 07:54:00 EDT 2009
Hi Thomas,
Great initiative you had here. I've just tested it. Build went well.
For python build, I had to modify setup.py at line 87 for it to find
mapserver-config :
-- def get_config(option, config='mapserver-config'):
++def get_config(option, config='../../mapserver-config'):
After build went on, import mapscript rises an error :
 File "mapscript.py", line 81, in <module>
    MS_VERSION_MAJOR = _mapscript.MS_VERSION_MAJOR
AttributeError: 'module' object has no attribute 'MS_VERSION_MAJOR'
Please note I didn't run python setup.py install, but only ran python
console from where mapscript.py was. I'm running Python 2.5.2 on Ubuntu 8.4
Did I miss something ?
Regards
Guillaume
Thomas Bonfort a écrit :
> I've committed the changes in https://svn.osgeo.org/mapserver/sandbox/aggfork
> * remove dependency on external agg library
> * agg support is added by default unless disabled with --with-agg=no
> * imported the agg 2.4 source directory, and patched it to be in the
> mapserver:: namespace
> * patched mapagg.cpp and mapagg.h do use the correct headers and the
> the win32 build will have be updated to compile and link the .cpp/.o
> files in renderers/agg/src
> a quick test on my system shows no problem (aside from some configure
> quirks, you have to add --enable-freetype, but I'll fix that soon),
> and I can now load the python mapscript module without a hiccup.
> Please test if you can, I'll commit this to the trunk around the end
> of next week if no problems arise until then.
> best regards,
> thomas
> On Fri, Apr 24, 2009 at 5:41 PM, Howard Butler <hobu.inc at gmail.com> wrote:
>> I am also generally supportive of this because of the user and maintenance
>> headaches, but I would caution that a concern of mine is the MapScript side
>> of the fence.  For example, matplotlib is a Python library that uses AGG
>> underneath.  When we had GD in the mix, a problem was our clashing with
>> PHP's internal GD.  Since AGG is fancy C++ :), I'm wondering if it would be
>> possible to put our fork of the AGG under a namespace to prevent symbol
>> clashes.
>> On Apr 24, 2009, at 8:53 AM, Yewondwossen Assefa wrote:
>>> For windows build, we have a mscv makefile which I believe is not part of
>>> the agg project. We are using it as part of the ms4w/osgeo4w build process.
>>> If we go ahead with this, I can commit that makefile.
>>> Overall, I don't see any problems for people building on windows so I am
>>>  +1
>>> Assefa
>>> Thomas Bonfort wrote:
>>>> Devs,
>>>> I foresee this might by stirring a can of worms given the precedent
>>>> with the GD library, but I would like to propose that we stop relying
>>>> on an external agg library, and pull in our own subset of agg in the
>>>> mapserver source tree:
>>>> * most of the agg code is templated, which means that the agg external
>>>> library actually only contains a tiny subset of what we're using
>>>> anyways.
>>>> * building agg is a pain for our users (Makefile needs to be patched
>>>> (adding -fPIC and building a shared library), and some distro's
>>>> package are just plain broken (rhel notably). This is my primary
>>>> motivation for the modification.
>>>> * the design intent of the library was to be directly included in
>>>> project trees rather than being built as a library
>>>> * the agg project is to the least not very lively. It has been taken
>>>> over by the community, but for the time being this has limited itself
>>>> to having a large list of commiters but no actual coding going on. As
>>>> such I do not see it evolving in a near future.
>>>> * there would be no change in the mapserver code, only Makefile
>>>> modifications.
>>>> If we decide to go down this route, I volunteer to maintain the
>>>> imported code and the corresponding Makefiles.
>>>> so:
>>>> - can the mapscript maintainers speak up if this can be disruptive ?
>>>> - bring on the flames :)
>>>> best regards,
>>>> thomas
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Email: assefa at dmsolutions.ca
>>> http://www.dmsolutions.ca/
>>> Phone: (613) 565-5056 (ext 14)
>>> Fax:   (613) 565-0925
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
