[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
teeschke
daniel.teske at web.de
Thu Aug 20 11:05:54 EDT 2009
Dear List..
actually I'm comparing my current used Mapserver (5.0.2) with the actual
(5.4.2) and I detected a strange side effect when a size assigned to a gif
symbol:
size < gif size: the symbol gets brightly
size > gif size: the symbol gets darkly
here is my sample code for your better reproduction:
Part of my Symbolset:
SYMBOL
NAME 'some_gif_symbol'
TYPE PIXMAP
IMAGE "some_gif_symbol.gif"
END
Part of my Mapfile:
LAYER
NAME 'dw_mg_geom_view'
STATUS ON
TYPE POINT
DATA "some_shape"
TEMPLATE 'foo.html'
LABELITEM 'KARTO_NR'
CLASS
NAME '1-3 (size < gif size)'
EXPRESSION (1 <= [KARTO_NR] AND [KARTO_NR] <= 3)
STYLE
SYMBOL 'some_gif_symbol'
SIZE 10 #equals gif size -3
END #STYLE
LABEL
FONT arial
TYPE TRUETYPE
SIZE 9
POSITION AUTO
COLOR 0 0 0
END #LABEL
END #CLASS
CLASS
NAME '3-6 (size = gif size)'
EXPRESSION (3 < [KARTO_NR] AND [KARTO_NR] <= 6)
STYLE
SIZE 13 #equals gif size
END #STYLE
LABEL
FONT arial
TYPE TRUETYPE
SIZE 9
POSITION AUTO
COLOR 0 0 0
END #LABEL
END #CLASS
CLASS
NAME '6-9 (size > gif size)'
EXPRESSION (6 < [KARTO_NR] AND [KARTO_NR] <= 9)
STYLE
SIZE 16 #equals gif size +3
END #STYLE
LABEL
FONT arial
TYPE TRUETYPE
SIZE 9
POSITION AUTO
COLOR 0 0 0
END #LABEL
END #CLASS
END #LAYER
the 13x13 gif symbol:
http://n2.nabble.com/file/n3479658/some_gif_symbol.gif
the getmap result:
http://n2.nabble.com/file/n3479658/getmap.png
This phenomenon happens only in the 5.4.2! the 5.0.2 works correct.
In the Changelog I found something: "Made sure computation of default symbol
size is consistent with older versions (#2963)"
Thanks and best regards..
..Daniel
View this message in context: http://n2.nabble.com/strange-behavior-when-size-gif-size-UMN-5-4-2-tp3479658p3479658.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
