[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Aug 20 11:12:08 EDT 2009
What output driver? GD or AGG?
>>> On 8/20/2009 at 10:05 AM, in message
<1250780754967-3479658.post at n2.nabble.com>, teeschke <daniel.teske at web.de>
wrote:
> Dear List..
> actually I'm comparing my current used Mapserver (5.0.2) with the actual
> (5.4.2) and I detected a strange side effect when a size assigned to a gif
> symbol:
> size < gif size: the symbol gets brightly
> size > gif size: the symbol gets darkly
> here is my sample code for your better reproduction:
> Part of my Symbolset:
> SYMBOL
> NAME 'some_gif_symbol'
> TYPE PIXMAP
> IMAGE "some_gif_symbol.gif"
> END
> Part of my Mapfile:
> LAYER
> NAME 'dw_mg_geom_view'
> STATUS ON
> TYPE POINT
> DATA "some_shape"
> TEMPLATE 'foo.html'
> LABELITEM 'KARTO_NR'
> CLASS
> NAME '1-3 (size < gif size)'
> EXPRESSION (1 <= [KARTO_NR] AND [KARTO_NR] <= 3)
> STYLE
> SYMBOL 'some_gif_symbol'
> SIZE 10 #equals gif size -3
> END #STYLE
> LABEL
> FONT arial
> TYPE TRUETYPE
> SIZE 9
> POSITION AUTO
> COLOR 0 0 0
> END #LABEL
> END #CLASS
> CLASS
> NAME '3-6 (size = gif size)'
> EXPRESSION (3 < [KARTO_NR] AND [KARTO_NR] <= 6)
> STYLE
> SIZE 13 #equals gif size
> END #STYLE
> LABEL
> FONT arial
> TYPE TRUETYPE
> SIZE 9
> POSITION AUTO
> COLOR 0 0 0
> END #LABEL
> END #CLASS
> CLASS
> NAME '6-9 (size > gif size)'
> EXPRESSION (6 < [KARTO_NR] AND [KARTO_NR] <= 9)
> STYLE
> SIZE 16 #equals gif size +3
> END #STYLE
> LABEL
> FONT arial
> TYPE TRUETYPE
> SIZE 9
> POSITION AUTO
> COLOR 0 0 0
> END #LABEL
> END #CLASS
> END #LAYER
> the 13x13 gif symbol:
> http://n2.nabble.com/file/n3479658/some_gif_symbol.gif
> the getmap result:
> http://n2.nabble.com/file/n3479658/getmap.png
> This phenomenon happens only in the 5.4.2! the 5.0.2 works correct.
> In the Changelog I found something: "Made sure computation of default symbol
> size is consistent with older versions (#2963)"
> Thanks and best regards..
> ..Daniel
