[mapserver-dev] Documentation of variable-substitution missleading
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Aug 21 10:37:20 EDT 2009
Stephan Holl wrote:
> Dear mapserver-devs,
> while playing with variable-substitution of mapserver I found the docs
> under
> http://mapserver.org/cgi/runsub.html
> missleading.
> I managed to make the validation when changing the *_string into
> *_pattern to make it work:
> did not work:
> METADATA
> 'multimedia_validation_string' '^yes|no$'
> 'sound_validation_string' '^yes|no$'
> 'nseats_validation_string' '^[0-9]{1,2}$'
> '... more metadata ...'
> END
> did work:
> METADATA
> 'multimedia_validation_pattern' '^yes|no$'
> 'sound_validation_pattern' '^yes|no$'
> 'nseats_validation_pattern' '^[0-9]{1,2}$'
> END
> btw, I used the substitution inside the CONNECTION-parameter to swith
> databases.
> Could you please update the docs.
Stephan,
Please file this documentation change as a ticket
(http://trac.osgeo.org/mapserver/), using the "MapServer Documentation"
component - otherwise this email will be forgotten.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
