[mapserver-dev] Documentation of variable-substitution missleading
Stephan Holl
stephan.holl at intevation.de
Mon Aug 24 03:08:41 EDT 2009
Hello Jeff,
Jeff McKenna <jmckenna at gatewaygeomatics.com>, [20090821 - 11:37:20]
> Stephan Holl wrote:
> > Dear mapserver-devs,
> > while playing with variable-substitution of mapserver I found the
> > docs under
> > http://mapserver.org/cgi/runsub.html
> > missleading.
> > I managed to make the validation when changing the *_string into
> > *_pattern to make it work:
> > did not work:
> > METADATA
> > 'multimedia_validation_string' '^yes|no$'
> > 'sound_validation_string' '^yes|no$'
> > 'nseats_validation_string' '^[0-9]{1,2}$'
> > '... more metadata ...'
> > END
> > did work:
> > METADATA
> > 'multimedia_validation_pattern' '^yes|no$'
> > 'sound_validation_pattern' '^yes|no$'
> > 'nseats_validation_pattern' '^[0-9]{1,2}$'
> > END
> > btw, I used the substitution inside the CONNECTION-parameter to
> > swith databases.
> > Could you please update the docs.
> Stephan,
> Please file this documentation change as a ticket
> (http://trac.osgeo.org/mapserver/), using the "MapServer
> Documentation" component - otherwise this email will be forgotten.
OK, thanks for looking into this.
Find the bug here:
http://trac.osgeo.org/mapserver/ticket/3102
Best
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090824/c4c390a3/signature.bin
