[mapserver-dev] mapserver crash on exit, with svn head geos
David Fuhry
dfuhry at acm.org
Tue Aug 25 22:20:56 EDT 2009
Steve,
Yes, someone patched GEOS HEAD shortly after I reported the bug. Fixed.
-Dave
Steve Lime wrote:
> David: Did the suggestion from the GEOS folks solve the issue?
> Steve
>>>> On 7/17/2009 at 3:57 PM, in message <4A60E59D.407 at acm.org>, David Fuhry
> <dfuhry at acm.org> wrote:
>> With GEOS from svn, mapserver crashes on calling exit(), as GEOS
>> destroys the static string defined in GEOS' WKBReader.cpp:
>> string WKBReader::BAD_GEOM_TYPE_MSG = "bad geometry type encountered in ";
>> It generally results in a corrupt image, as some glibc error messages
>> (the usual double-free stuff, I think; forgot to capture) are dumped in
>> the middle of the image output. I'm not sure of the ideal fix.
>> Inlining the few uses of BAD_GEOM_TYPE_MSG with the literal c-string
>> text works.
>> #0 0xb7f8a410 in ?? ()
>> #1 0xbfad8c5c in ?? ()
>> #2 0x00000006 in ?? ()
>> #3 0xb6656d68 in abort () from /lib/i686/cmov/libc.so.6
>> #4 0xb668cabd in __fsetlocking () from /lib/i686/cmov/libc.so.6
>> #5 0xb66971d4 in malloc_usable_size () from /lib/i686/cmov/libc.so.6
>> #6 0xb6699186 in free () from /lib/i686/cmov/libc.so.6
>> #7 0xb683ee91 in operator delete () from /usr/lib/libstdc++.so.6
>> #8 0xb681ac7d in std::string::_Rep::_M_destroy () from
>> #9 0xb681cb21 in std::basic_string<char, std::char_traits<char>,
>> std::allocator<char> >::~basic_string () from /usr/lib/libstdc++.so.6
>> #10 0xb61ee80c in __tcf_1 () at WKBReader.cpp:50
>> #11 0xb6658c21 in __cxa_finalize () from /lib/i686/cmov/libc.so.6
>> #12 0xb6162193 in __do_global_dtors_aux () from
>> /usr/local/lib/libgeos-3.2.0.so
>> #13 0xb62684ac in _fini () from /usr/local/lib/libgeos-3.2.0.so
>> #14 0xb7f99a23 in _dl_rtld_di_serinfo () from /lib/ld-linux.so.2
>> #15 0xb6658889 in exit () from /lib/i686/cmov/libc.so.6
>> #16 0x0805b795 in main (argc=2, argv=0xbfad9cb4) at mapserv.c:1877
>> -Dave
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
