[mapserver-dev] build problem: curl version and CURLOPT_PROXYAUTH
Martin Kofahl
M.Kofahl at gmx.net
Mon Dec 14 06:45:32 EST 2009
in the logs I found the message "HTTP request error. CURLOPT_PROXYAUTH not supported. Requires Curl 7.10.7 and up. *_proxy_auth_type setting ignored." but configure says
checking for curl-config... checking for curl-config... /usr/local/bin/curl-config
found libcurl version 7.19.4
OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
OGC WFS Client Connections enabled (-DUSE_WFS_LYR).
In curl.h (and there's only one on the system) CURLOPT_PROXYAUTH should be defined, so I wonder what's going wrong here.
/* Set this to a bitmask value to enable the particular authentications
methods you like. Use this in combination with CURLOPT_PROXYUSERPWD.
Note that setting multiple bits may cause extra network round-trips. */
CINIT(PROXYAUTH, LONG, 111),
Martin
