[mapserver-dev] Rendering a circle with the specified size as the default symbol
Tamas Szekeres szekerest at gmail.com
Thu Feb 5 10:09:47 EST 2009
Hi Thomas,
I'd be curious to know what level of detail will be chosen when selecting
the functions to be exposed in the vtable. I thought we'll probably select
those functions/operatons which are currently provide the branching between
the renderers.
In this particular case we would probably add a DrawMarkerSymbol to
represent the renderer specific msDrawMarkerSymbolGD / msDrawMarkerSymbolAGG
etc, variations.
In this regard it remains up to the renderer how the default symbol is drawn
in effect.
Would you describe in more details what you have in your mind about the
desired vtable architecture, I'm really interested in.
Best regards,
Tamas
2009/2/5 thomas bonfort <thomas.bonfort at gmail.com>
> Tamas,
> those kind of inconsistencies (as there are quite a few others) will
> hopefully be a thing of the past once we switch to the vtable
> rendering architecture. I'd favor leaving things as they are for 5.4
> and wait for 6.0 for introducing and documenting these changes.
> best regards,
> thomas
> On Thu, Feb 5, 2009 at 01:19, Tamas Szekeres <szekerest at gmail.com> wrote:
> > Folks,
> > Currently the GD and AGG renderer behaves differently when drawing a
> point
> > with no symbol specified. In the code I can see something like for AGG
> > if(style->symbol == 0) { // simply draw a circle of the specified color
> ren->renderEllipse(p->x+ox,p->y+oy,size,size,0,agg_color,agg_ocolor,width);
> >         return;
> > The corresponding code for GD looks like:
> > if(style->symbol == 0 && fc >= 0) { /* simply draw a single pixel of the
> > specified color */
> >     gdImageSetPixel(img, (int)(p->x + ox), (int)(p->y + oy), fc);
> >     return;
> > Wouldn't it be reasonable to use the same approach for the different
> > renderers? I would prefer the AGG version to be followed.
> > Best regards,
> > Tamas
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090205/f1ba0773/attachment.html
