[mapserver-dev] mapfile.c r8501
Paul Ramsey
pramsey at opengeo.org
Thu Feb 5 14:58:14 EST 2009
Steve, your change <http://trac.osgeo.org/mapserver/changeset/8501> at
r8501 is causing OS/X to blow chunks. It's not immediately obvious to
me, perhaps it is to you.
mapserv(13879) malloc: *** error for object 0x2ef3b: Non-aligned
pointer being freed
*** set a breakpoint in malloc_error_break to debug
Breakpoint 1, 0x91d884a9 in malloc_error_break ()
(gdb) bt
#0 0x91d884a9 in malloc_error_break ()
#1 0x91d83497 in szone_error ()
#2 0x91cad463 in szone_free ()
#3 0x91cad2cd in free ()
#4 0x00029861 in getString (s=0xbfffe72c) at mapfile.c:181
#5 0x0003028c in loadLayer (layer=0x180b000, map=0x180b600) at mapfile.c:2776
#6 0x00035b3b in loadMapInternal (map=0x180b600) at mapfile.c:4561
#7 0x0003680e in msLoadMap (filename=0x1205880
"/Users/pramsey/Code/topp-benchmarks/bench.map", new_mappath=0x0) at
mapfile.c:4786
#8 0x00002cb2 in loadMap () at mapserv.c:203
#9 0x00005a17 in main (argc=2, argv=0xbffff750) at mapserv.c:1214
