[mapserver-dev] Re: mapfile.c r8501
Paul Ramsey
pramsey at opengeo.org
Thu Feb 5 15:01:47 EST 2009
Saying it wasn't obvious made it obvious. Initializing *string to NULL
fixed everything up.
P.
On Thu, Feb 5, 2009 at 11:58 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Steve, your change <http://trac.osgeo.org/mapserver/changeset/8501> at
> r8501 is causing OS/X to blow chunks. It's not immediately obvious to
> me, perhaps it is to you.
> mapserv(13879) malloc: *** error for object 0x2ef3b: Non-aligned
> pointer being freed
> *** set a breakpoint in malloc_error_break to debug
> Breakpoint 1, 0x91d884a9 in malloc_error_break ()
> (gdb) bt
> #0 0x91d884a9 in malloc_error_break ()
> #1 0x91d83497 in szone_error ()
> #2 0x91cad463 in szone_free ()
> #3 0x91cad2cd in free ()
> #4 0x00029861 in getString (s=0xbfffe72c) at mapfile.c:181
> #5 0x0003028c in loadLayer (layer=0x180b000, map=0x180b600) at mapfile.c:2776
> #6 0x00035b3b in loadMapInternal (map=0x180b600) at mapfile.c:4561
> #7 0x0003680e in msLoadMap (filename=0x1205880
> "/Users/pramsey/Code/topp-benchmarks/bench.map", new_mappath=0x0) at
> mapfile.c:4786
> #8 0x00002cb2 in loadMap () at mapserv.c:203
> #9 0x00005a17 in main (argc=2, argv=0xbffff750) at mapserv.c:1214
