[mapserver-dev] WFS 1.1.0 Server and lat/long axis order
Paul Ramsey pramsey at opengeo.org
Fri Feb 20 15:57:41 EST 2009
If you do the request via WFS 1.0 does it come out correct? This is
exactly the tower-of-babel I predicted when I starting hammering on
axis ordering in WFS back in 2005.
P.
On Fri, Feb 20, 2009 at 12:36 PM, Kralidis,Tom [Ontario]
<Tom.Kralidis at ec.gc.ca> wrote:
> We recently stood up 5.2.1 to offer up corporate WMS, WFS, WCS and SOS
> interfaces.
> We have MAP.PROJECTION set to init=epsg:4326.
> We don't have MAP.WEB.METADATA.wfs_srs set.
> We have MAP.LAYER.METADATA.PROJECTION set (to each layer's native
> projection)
> WFS 1.1.0 shows EPSG:4326 as the DefaultSRS for the FeatureType in
> question (probably fetching from MAP.PROJECTION?).
> A colleague has noticed that connecting to our endpoint using WFS 1.1.0,
> through ESRI ArcMap.  ArcMap renders the features flipped.
> Searching a bit more, we found:
> http://n2.nabble.com/WFS-lat-lon-coordinates-switched-in-ArcGIS-td205507
> 9.html
> When I try in QGIS, the WFS renders fine.
> Anyone have suggestions?  Can WFS offer up > 1 SRS?  This would be
> _non-trivial_ change to the codebase.
> ..Tom
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
