[mapserver-dev] WFS 1.1.0 Server and lat/long axis order
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Fri Feb 20 16:00:24 EST 2009
Well, apparently (I don't have ArcMap) the interoperability extension
ArcMap is using does _not_ allow you specify the version for WFS, so it
grabs 1.1.0 (latest).  For WMS it allows you to specify version.
We found a workaround by tacking on "version=1.0.0" to the base URL, but
there's a greater issue at hand :)
..Tom
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Paul Ramsey
> Sent: Friday, 20 February 2009 15:58
> To: Kralidis,Tom [Ontario]
> Cc: mapserver-dev
> Subject: Re: [mapserver-dev] WFS 1.1.0 Server and lat/long axis order
> If you do the request via WFS 1.0 does it come out correct?
> This is exactly the tower-of-babel I predicted when I
> starting hammering on axis ordering in WFS back in 2005.
> P.
> On Fri, Feb 20, 2009 at 12:36 PM, Kralidis,Tom [Ontario]
> <Tom.Kralidis at ec.gc.ca> wrote:
> > We recently stood up 5.2.1 to offer up corporate WMS, WFS,
> WCS and SOS
> > interfaces.
> > We have MAP.PROJECTION set to init=epsg:4326.
> > We don't have MAP.WEB.METADATA.wfs_srs set.
> > We have MAP.LAYER.METADATA.PROJECTION set (to each layer's native
> > projection)
> > WFS 1.1.0 shows EPSG:4326 as the DefaultSRS for the FeatureType in
> > question (probably fetching from MAP.PROJECTION?).
> > A colleague has noticed that connecting to our endpoint using WFS
> > 1.1.0, through ESRI ArcMap.  ArcMap renders the features flipped.
> > Searching a bit more, we found:
> http://n2.nabble.com/WFS-lat-lon-coordinates-switched-in-ArcGIS-td2055
> > 07
> > 9.html
> > When I try in QGIS, the WFS renders fine.
> > Anyone have suggestions?  Can WFS offer up > 1 SRS?  This would be
> > _non-trivial_ change to the codebase.
> > ..Tom
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
