[mapserver-dev] WFS 1.1.0 Server and lat/long axis order
Paul Ramsey
pramsey at opengeo.org
Wed Feb 25 11:55:28 EST 2009
When the interop extension makes the data request, what form does it
use for the SRS? "EPSG:XXXX" or "urn://blahblah"?
P
On Fri, Feb 20, 2009 at 1:00 PM, Kralidis,Tom [Ontario]
<Tom.Kralidis at ec.gc.ca> wrote:
> Well, apparently (I don't have ArcMap) the interoperability extension
> ArcMap is using does _not_ allow you specify the version for WFS, so it
> grabs 1.1.0 (latest). For WMS it allows you to specify version.
> We found a workaround by tacking on "version=1.0.0" to the base URL, but
> there's a greater issue at hand :)
> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
>> Paul Ramsey
>> Sent: Friday, 20 February 2009 15:58
>> To: Kralidis,Tom [Ontario]
>> Cc: mapserver-dev
>> Subject: Re: [mapserver-dev] WFS 1.1.0 Server and lat/long axis order
>> If you do the request via WFS 1.0 does it come out correct?
>> This is exactly the tower-of-babel I predicted when I
>> starting hammering on axis ordering in WFS back in 2005.
>> P.
>> On Fri, Feb 20, 2009 at 12:36 PM, Kralidis,Tom [Ontario]
>> > We recently stood up 5.2.1 to offer up corporate WMS, WFS,
>> WCS and SOS
>> > interfaces.
>> > We have MAP.PROJECTION set to init=epsg:4326.
>> > We don't have MAP.WEB.METADATA.wfs_srs set.
>> > We have MAP.LAYER.METADATA.PROJECTION set (to each layer's native
>> > projection)
>> > WFS 1.1.0 shows EPSG:4326 as the DefaultSRS for the FeatureType in
>> > question (probably fetching from MAP.PROJECTION?).
>> > A colleague has noticed that connecting to our endpoint using WFS
>> > 1.1.0, through ESRI ArcMap. ArcMap renders the features flipped.
>> > Searching a bit more, we found:
>> http://n2.nabble.com/WFS-lat-lon-coordinates-switched-in-ArcGIS-td2055
>> > 07
>> > 9.html
>> > When I try in QGIS, the WFS renders fine.
>> > Anyone have suggestions? Can WFS offer up > 1 SRS? This would be
>> > _non-trivial_ change to the codebase.
>> > ..Tom
>> > _______________________________________________
>> > mapserver-dev mailing list
>> > mapserver-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
