[mapserver-dev] Map server
Phalguni Pal
phalguni.pal at gmail.com
Mon Feb 23 11:27:41 EST 2009
Hi
I am trying to display few points on the browser using Mapserver. I have
created MySQL database and created connection with mapserver by the help of
.ovf xml file.
<OGRVRTDataSource>
<OGRVRTLayer name="nsdb">
<SrcDataSource>MYSQL:dispro,user=uuuuuu,password=pppp,host=192.170.1.100,port=3306,tables=STATION</SrcDataSource>
<SrcSQL>SELECT absnum, stlat, stlon, stflag FROM STATION</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="stlon" y="stlat"/>
</OGRVRTLayer>
</OGRVRTDataSource>
When I run the command :
ogrinfo /mnt/fritjof/wms/nsdb/con.ovf
ogrinfo returns :
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `/mnt/fritjof/wms/nsdb/con.ovf'
using driver `VRT' successful.
1: nsdb (Point)
I have a map file con.map as follows:
MAP
NAME "MYSQL-TEST"
EXTENT -180 -90 180 90
UNITS dd
CONFIG "CPL_DEBUG" "ON"
PROJECTION
"init=epsg:4326"
END
SHAPEPATH "/mnt/fritjof/wms/nsdb"
LAYER
DEBUG ON
METADATA
"wms_title" "nsdb"
"wms_srs" "EPSG:4326"
"wms_extent" "-57.768 64.1842 -51.6283 64.3645"
END
NAME "stations"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "con.ovf"
DATA "nsdb"
PROJECTION
"init=epsg:4326"
END
EXTENT -57.768 64.1842 -51.6283 64.3645
CLASS
NAME "MyClass"
STYLE
SYMBOL 1
SIZE 15
COLOR 255 0 0
END
END
END
END
And I have another html form:
MAPFILE
REQUEST
SERVICE
VERSION
LAYERS
STYLES
SRS
BBOX
WIDTH
HEIGHT
FORMAT
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090223/31be93fe/attachment.html
