[mapserver-dev] WFS 1.1.0 Server and lat/long axis order
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Thu Feb 26 12:55:50 EST 2009
FYI I've added a ticket on this at http://trac.osgeo.org/mapserver/ticket/2899 and added to the TO sprint MapServer items.
..Tom
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Sent: Wednesday, 25 February 2009 14:21
> To: Paul Ramsey
> Cc: mapserver-dev
> Subject: RE: [mapserver-dev] WFS 1.1.0 Server and lat/long axis order
> It doesn't pass the SRS. Here's what the WFS connector does:
> "GET
> /cgi-bin/mapserv/mapserv?SERVICE=WFS&VERSION=1.1.0&REQUEST=Get
> Feature&MAP=/tmp/pa/config_en.map&TYPENAME=pa HTTP/1.1"
> ..Tom
> > From: pramsey at cleverelephant.ca
> > [mailto:pramsey at cleverelephant.ca] On Behalf Of Paul Ramsey
> > Sent: Wednesday, 25 February 2009 11:55
> > To: Kralidis,Tom [Ontario]
> > Cc: mapserver-dev
> > Subject: Re: [mapserver-dev] WFS 1.1.0 Server and lat/long
> axis order
> > When the interop extension makes the data request, what
> form does it
> > use for the SRS? "EPSG:XXXX" or "urn://blahblah"?
> > P
> > On Fri, Feb 20, 2009 at 1:00 PM, Kralidis,Tom [Ontario]
> > <Tom.Kralidis at ec.gc.ca> wrote:
> > > Well, apparently (I don't have ArcMap) the interoperability
> > extension
> > > ArcMap is using does _not_ allow you specify the version
> > for WFS, so
> > > it grabs 1.1.0 (latest). For WMS it allows you to
> specify version.
> > > We found a workaround by tacking on "version=1.0.0" to the
> > base URL,
> > > but there's a greater issue at hand :)
> > > ..Tom
> > >> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Paul
> > >> Ramsey
> > >> Sent: Friday, 20 February 2009 15:58
> > >> Cc: mapserver-dev
> > axis order
> > >> If you do the request via WFS 1.0 does it come out correct?
> > >> This is exactly the tower-of-babel I predicted when I starting
> > >> hammering on axis ordering in WFS back in 2005.
> > >> P.
> > >> On Fri, Feb 20, 2009 at 12:36 PM, Kralidis,Tom [Ontario]
> > >> > We recently stood up 5.2.1 to offer up corporate WMS, WFS,
> > >> WCS and SOS
> > >> > interfaces.
> > >> > We have MAP.PROJECTION set to init=epsg:4326.
> > >> > We don't have MAP.WEB.METADATA.wfs_srs set.
> > >> > We have MAP.LAYER.METADATA.PROJECTION set (to each
> layer's native
> > >> > projection)
> > >> > WFS 1.1.0 shows EPSG:4326 as the DefaultSRS for the
> > FeatureType in
> > >> > question (probably fetching from MAP.PROJECTION?).
> > >> > A colleague has noticed that connecting to our endpoint
> > using WFS
> > >> > 1.1.0, through ESRI ArcMap. ArcMap renders the
> features flipped.
> > >> > Searching a bit more, we found:
> http://n2.nabble.com/WFS-lat-lon-coordinates-switched-in-ArcGIS-td205
> > >> 5
> > >> > 07
> > >> > 9.html
> > >> > When I try in QGIS, the WFS renders fine.
> > >> > Anyone have suggestions? Can WFS offer up > 1 SRS?
> > This would be
> > >> > _non-trivial_ change to the codebase.
> > >> > ..Tom
> > >> > _______________________________________________
> > >> > mapserver-dev mailing list
> > >> > mapserver-dev at lists.osgeo.org
> > >> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
