[mapserver-dev] "Diagnostic"/Testing Mapfile
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 24 09:59:10 EST 2009
Dan,
I had been considering the same thing. Perhaps reviewing msautotest (http://www.mapserver.org/development/tests/autotest.html) would be a good start? There's a "misc" folder containing rendering output (and query results, etc). At the very least we should be prepared to add a set of tests for PDF (and SVG?) output to the msautotest suite...
Brent Fraser
Dan Little wrote:
> Does anyone have a mapfile that has a comprehensive set of tests for, say, all of the drawing operations?
> I understand it might be a lot to ask for, but I've got the cairo code working and wanted to run it through some paces to make a "to do" list for what will need to be completed.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
