[mapserver-dev] default values when using url overloading
Daniel Morissette
dmorissette at mapgears.com
Wed Jul 29 11:52:58 EDT 2009
Thomas Bonfort wrote:
> I very often use url overloading with the %key% syntax in my mapfile
> as I find it's a powerful means of building custom maps. The problem
> with the current implementation is that the mapfile more often than
> less becomes unparsable if the url doesn't contain the key=value
> parameter.
> Would it be complicated to modify the parser so that the mapfile can
> contain a default value for %key%, that would be applied if the url
> does not contain the "key" parameter?
I have encountered that problem as well and think this would be a
valuable addition.
Perhaps it could be as simple as looking up the %key% value in metadata
if it is not present in the URL?
Daniel
Daniel Morissette
http://www.mapgears.com/
