[mapserver-dev] default values when using url overloading
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jul 29 12:38:42 EDT 2009
Problem is that it's the presence of a parameter in the URL that causes the code to
check if something needs overloaded. So, for each url variable 'key' we look for %key%
in supported places and also apply validation (if supplied).
To do this we'd need to be able to define a list of supported keys and work through
that instead of the entire list passed as part of a request. With that it would be easy
to define a default somehow, likely through metadata.
Steve
>>> On 7/29/2009 at 10:52 AM, in message <4A70705A.2090403 at mapgears.com>, Daniel
Morissette <dmorissette at mapgears.com> wrote:
> Thomas Bonfort wrote:
>> I very often use url overloading with the %key% syntax in my mapfile
>> as I find it's a powerful means of building custom maps. The problem
>> with the current implementation is that the mapfile more often than
>> less becomes unparsable if the url doesn't contain the key=value
>> parameter.
>> Would it be complicated to modify the parser so that the mapfile can
>> contain a default value for %key%, that would be applied if the url
>> does not contain the "key" parameter?
> I have encountered that problem as well and think this would be a
> valuable addition.
> Perhaps it could be as simple as looking up the %key% value in metadata
> if it is not present in the URL?
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
