[mapserver-dev] LAYER EXTENT
Tamas Szekeres szekerest at gmail.com
Thu Jun 4 14:56:09 EDT 2009
Hi Paul,
layer->extent is used to provide data for msLayerGetExtent. If layer->extent
is set then this value is used, otherwise the  driver-specific
implementation is called which may be much slower and some of the drivers
don't implement to retrieve it. I assume layer->extent is defined in the
layer coordinate system.
I think you could easily use this in msLayerIsVisible (assuming it does
nothing if the extent is not set ). I don't see the necessity have an RFC
with this.
Best regards,
Tamas
2009/6/4 Paul Ramsey <pramsey at opengeo.org>
> I see we have an EXTENT keyword under LAYER, but poking around the
> code, layerObj->extent is not used very much.
> I have a client request to use LAYER EXTENT as a processing short
> circuit, so that layers whose extent does not intersect the map extent
> can be quickly skipped (probably at the point where msLayerIsVisible()
> is called).
> First, does this feel RFC worthy? (My feeling is "no", it's just an
> enhancement of existing behavior)
> Second, what are the expected semantics of the coordinates in LAYER
> EXTENT. Are they in the LAYER projection or the MAP projection? (My
> feeling is, LAYER).
> Thanks,
> Paul
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090604/1ecc0567/attachment.html
