[mapserver-dev] GAP with TTF symbols changed behavior in MapServer
5.0
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jun 5 15:20:28 EDT 2009
If I recall correctly, 4.10 was wrong. Prior to 4.10, the behavior was
the same as 5.0. I have not verified this as a fact, but that is my
memory of this.
Regardless, this does not impact me either. Unless this is going to
create major heartburn for a large site, I would opt to move forward
with putting the ANGLE and GAP in the style object which I think
provides for greater flexibility and more labeling options than we have
today with cleaner code.
-Steve W
Daniel Morissette wrote:
> Thomas Bonfort wrote:
>> I'll take the blame for that one, I made that change to follow the
>> documentation (which doesn't state that the symbol stays top-up, but
>> that a 180 degree rotation is applied). Not sure this is ever used
>> though, as there have been no bugs filed on this in nearly two years.
> You're right that the documentation doesn't provide a good description
> of the behavior (whether it's the old one or the new one)... but before
> fixing it I wanted to make sure it was not me who had missed something.
> I've created a ticket for the docs:
> http://trac.osgeo.org/mapserver/ticket/3045
>> I'm not against reeanbling the previous behavior, although this would
>> remove the possibility to specify a simple that repeats along a line
>> but does not follow its orientation. I guess this can be overcome in
>> future versions, where GAP is moved into the styleObj, and angle can
>> be AUTO.
> I'm not sure if we should re-enable the old behavior or not. I don't
> have a need for it personally and a case can be made for a symbol with
> no rotation too. At this point I am mostly concerned about getting the
> docs right.
> What do others think?
> Daniel
