[mapserver-dev] Shapefile goes from 1 sec to 90+ sec just adding a
labels!
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jun 10 13:07:00 EDT 2009
Hi all,
I have run into a very bazaar problem with a shapefile going from 1
second render times to ~50 second render times just for the geometry,
not the label cache when I add labels to the layer.
I can reproduce this with just one layer and one shapefile.
Has anyone else run into anything like this?
-Steve
MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
MAP
MAXSIZE 4000
SIZE 800 800
SHAPEPATH "/u/data/data/Jamaica-900913"
SYMBOLSET "/u/data/data/Jamaica-900913/symbols/symbols.sym"
FONTSET "/u/data/data/Jamaica-900913/symbols/fontset.txt"
IMAGECOLOR "#80B1D3"
IMAGETYPE agg
EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
UNITS METERS
DEBUG 10
CONFIG MS_ERRORFILE "stderr"
OUTPUTFORMAT
NAME agg
DRIVER "AGG/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
WEB
METADATA
wms_srs "epsg:900913"
labelcache_map_edge_buffer "-10"
wms_title "jamaica data"
END
END
LAYER
NAME "World"
GROUP "cb"
STATUS DEFAULT
TYPE POLYGON
DATA "world/world"
CLASSITEM "COLOR"
LABELITEM "NAME"
CLASS
EXPRESSION "1"
STYLE
COLOR "#99B3FF"
OUTLINECOLOR "#888888"
END
LABEL
TYPE TRUETYPE FONT "arial" SIZE 7 COLOR "#010101" PARTIALS
FALSE OUTLINEWIDTH 3
PRIORITY 8
BUFFER 4 POSITION CC MINDISTANCE 250 MINFEATURESIZE 10
END
END
CLASS
EXPRESSION "2"
STYLE
COLOR "#B3FF99"
END
LABEL
PRIORITY 8
END
END
CLASS
EXPRESSION "3"
STYLE
COLOR "#FFE699"
END
LABEL
PRIORITY 8
END
END
CLASS
EXPRESSION "4"
STYLE
COLOR "#FFB399"
END
LABEL
PRIORITY 8
END
END
CLASS
EXPRESSION "5"
STYLE
COLOR "#99FFB3"
END
LABEL
PRIORITY 8
END
END
END
END
Here is the log of just zooming out:
[Wed Jun 10 12:53:35 2009].323025 msDrawMap(): Layer 0 (World), 0.422s
[Wed Jun 10 12:53:35 2009].323329 msDrawLabelCache():
labelcache_map_edge_buffer = -10
[Wed Jun 10 12:53:35 2009].336325 msDrawMap(): Drawing Label Cache, 0.013s
[Wed Jun 10 12:53:35 2009].336355 msDrawMap() total time: 0.438s
[Wed Jun 10 12:53:35 2009].357835 msSaveImage() total time: 0.021s
[Wed Jun 10 12:53:35 2009].358140 mapserv request processing time
(loadmap not incl.): 0.460s
[Wed Jun 10 12:53:35 2009].358160 msFreeMap(): freeing map at 0x63aa00.
[Wed Jun 10 12:53:36 2009].994979 msDrawMap(): Layer 0 (World), 0.786s
[Wed Jun 10 12:53:36 2009].995292 msDrawLabelCache():
[Wed Jun 10 12:53:37 2009].7982 msDrawMap(): Drawing Label Cache, 0.013s
[Wed Jun 10 12:53:37 2009].8014 msDrawMap() total time: 0.801s
[Wed Jun 10 12:53:37 2009].29497 msSaveImage() total time: 0.021s
[Wed Jun 10 12:53:37 2009].29769 mapserv request processing time
(loadmap not incl.): 0.823s
[Wed Jun 10 12:53:37 2009].29789 msFreeMap(): freeing map at 0x63aa00.
[Wed Jun 10 12:53:41 2009].780255 msDrawMap(): Layer 0 (World), 3.827s
[Wed Jun 10 12:53:41 2009].780566 msDrawLabelCache():
[Wed Jun 10 12:53:41 2009].795910 msDrawMap(): Drawing Label Cache, 0.015s
[Wed Jun 10 12:53:41 2009].795941 msDrawMap() total time: 3.845s
[Wed Jun 10 12:53:41 2009].818499 msSaveImage() total time: 0.023s
[Wed Jun 10 12:53:41 2009].818785 mapserv request processing time
(loadmap not incl.): 3.868s
[Wed Jun 10 12:53:41 2009].818805 msFreeMap(): freeing map at 0x63aa10.
[Wed Jun 10 12:54:40 2009].258306 msDrawMap(): Layer 0 (World), 56.436s
[Wed Jun 10 12:54:40 2009].258634 msDrawLabelCache():
[Wed Jun 10 12:54:40 2009].293897 msDrawMap(): Drawing Label Cache, 0.035s
[Wed Jun 10 12:54:40 2009].293931 msDrawMap() total time: 56.474s
[Wed Jun 10 12:54:40 2009].320803 msSaveImage() total time: 0.027s
[Wed Jun 10 12:54:40 2009].321088 mapserv request processing time
(loadmap not incl.): 56.501s
[Wed Jun 10 12:54:40 2009].321110 msFreeMap(): freeing map at 0x63aa00.
[Wed Jun 10 12:56:10 2009].600928 msDrawMap(): Layer 0 (World), 49.215s
[Wed Jun 10 12:56:10 2009].601264 msDrawLabelCache():
[Wed Jun 10 12:56:10 2009].629768 msDrawMap(): Drawing Label Cache, 0.029s
[Wed Jun 10 12:56:10 2009].629802 msDrawMap() total time: 49.246s
[Wed Jun 10 12:56:10 2009].655105 msSaveImage() total time: 0.025s
[Wed Jun 10 12:56:10 2009].655601 mapserv request processing time
(loadmap not incl.): 49.272s
[Wed Jun 10 12:56:10 2009].655623 msFreeMap(): freeing map at 0x63aa10.
