[mapserver-dev] Shapefile goes from 1 sec to 90+ sec just adding a labels!
Paul Ramsey pramsey at cleverelephant.ca
Wed Jun 10 13:09:46 EDT 2009
That's awesome. Want to roll up the data/symbols/fonts into a zip file?
P
On Wed, Jun 10, 2009 at 10:07 AM, Stephen
Woodbridge<woodbri at swoodbridge.com> wrote:
> Hi all,
> I have run into a very bazaar problem with a shapefile going from 1 second
> render times to ~50 second render times just for the geometry, not the label
> cache when I add labels to the layer.
> I can reproduce this with just one layer and one shapefile.
> Has anyone else run into anything like this?
> -Steve
> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> MAP
>  MAXSIZE 4000
>  SIZE 800 800
>  SHAPEPATH "/u/data/data/Jamaica-900913"
>  SYMBOLSET "/u/data/data/Jamaica-900913/symbols/symbols.sym"
>  FONTSET "/u/data/data/Jamaica-900913/symbols/fontset.txt"
>  IMAGECOLOR "#80B1D3"
>  IMAGETYPE agg
>  EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
>  UNITS METERS
>  DEBUG 10
>  CONFIG MS_ERRORFILE "stderr"
>  OUTPUTFORMAT
>    NAME agg
>    DRIVER "AGG/PNG"
>    EXTENSION "png"
>    MIMETYPE "image/png"
>    IMAGEMODE RGB
>    FORMATOPTION "INTERLACE=false"
>    FORMATOPTION "QUANTIZE_FORCE=ON"
>    FORMATOPTION "QUANTIZE_DITHER=OFF"
>    FORMATOPTION "QUANTIZE_COLORS=256"
>  END
>  WEB
>    METADATA
>      wms_srs "epsg:900913"
>      labelcache_map_edge_buffer "-10"
>      wms_title "jamaica data"
>    END
>  END
>  LAYER
>    NAME "World"
>    GROUP "cb"
>    STATUS DEFAULT
>    TYPE POLYGON
>    DATA "world/world"
>    CLASSITEM "COLOR"
>    LABELITEM "NAME"
>    CLASS
>      EXPRESSION "1"
>      STYLE
>        COLOR "#99B3FF"
>        OUTLINECOLOR "#888888"
>      END
>      LABEL
>        TYPE TRUETYPE FONT "arial" SIZE 7 COLOR "#010101" PARTIALS FALSE
> OUTLINEWIDTH 3
>        PRIORITY 8
>        BUFFER 4 POSITION CC MINDISTANCE 250 MINFEATURESIZE 10
>      END
>    END
>    CLASS
>      EXPRESSION "2"
>      STYLE
>        COLOR "#B3FF99"
>      END
>      LABEL
> OUTLINEWIDTH 3
>        PRIORITY 8
>      END
>    END
>    CLASS
>      EXPRESSION "3"
>      STYLE
>        COLOR "#FFE699"
>      END
>      LABEL
> OUTLINEWIDTH 3
>        PRIORITY 8
>      END
>    END
>    CLASS
>      EXPRESSION "4"
>      STYLE
>        COLOR "#FFB399"
>      END
>      LABEL
> OUTLINEWIDTH 3
>        PRIORITY 8
>      END
>    END
>    CLASS
>      EXPRESSION "5"
>      STYLE
>        COLOR "#99FFB3"
>      END
>      LABEL
> OUTLINEWIDTH 3
>        PRIORITY 8
>      END
>    END
>  END
> END
> Here is the log of just zooming out:
> [Wed Jun 10 12:53:35 2009].323025 msDrawMap(): Layer 0 (World), 0.422s
> [Wed Jun 10 12:53:35 2009].323329 msDrawLabelCache():
> labelcache_map_edge_buffer = -10
> [Wed Jun 10 12:53:35 2009].336325 msDrawMap(): Drawing Label Cache, 0.013s
> [Wed Jun 10 12:53:35 2009].336355 msDrawMap() total time: 0.438s
> [Wed Jun 10 12:53:35 2009].357835 msSaveImage() total time: 0.021s
> [Wed Jun 10 12:53:35 2009].358140 mapserv request processing time (loadmap
> not incl.): 0.460s
> [Wed Jun 10 12:53:35 2009].358160 msFreeMap(): freeing map at 0x63aa00.
> [Wed Jun 10 12:53:36 2009].994979 msDrawMap(): Layer 0 (World), 0.786s
> [Wed Jun 10 12:53:36 2009].995292 msDrawLabelCache():
> [Wed Jun 10 12:53:37 2009].7982 msDrawMap(): Drawing Label Cache, 0.013s
> [Wed Jun 10 12:53:37 2009].8014 msDrawMap() total time: 0.801s
> [Wed Jun 10 12:53:37 2009].29497 msSaveImage() total time: 0.021s
> [Wed Jun 10 12:53:37 2009].29769 mapserv request processing time (loadmap
> not incl.): 0.823s
> [Wed Jun 10 12:53:37 2009].29789 msFreeMap(): freeing map at 0x63aa00.
> [Wed Jun 10 12:53:41 2009].780255 msDrawMap(): Layer 0 (World), 3.827s
> [Wed Jun 10 12:53:41 2009].780566 msDrawLabelCache():
> [Wed Jun 10 12:53:41 2009].795910 msDrawMap(): Drawing Label Cache, 0.015s
> [Wed Jun 10 12:53:41 2009].795941 msDrawMap() total time: 3.845s
> [Wed Jun 10 12:53:41 2009].818499 msSaveImage() total time: 0.023s
> [Wed Jun 10 12:53:41 2009].818785 mapserv request processing time (loadmap
> not incl.): 3.868s
> [Wed Jun 10 12:53:41 2009].818805 msFreeMap(): freeing map at 0x63aa10.
> [Wed Jun 10 12:54:40 2009].258306 msDrawMap(): Layer 0 (World), 56.436s
> [Wed Jun 10 12:54:40 2009].258634 msDrawLabelCache():
> [Wed Jun 10 12:54:40 2009].293897 msDrawMap(): Drawing Label Cache, 0.035s
> [Wed Jun 10 12:54:40 2009].293931 msDrawMap() total time: 56.474s
> [Wed Jun 10 12:54:40 2009].320803 msSaveImage() total time: 0.027s
> [Wed Jun 10 12:54:40 2009].321088 mapserv request processing time (loadmap
> not incl.): 56.501s
> [Wed Jun 10 12:54:40 2009].321110 msFreeMap(): freeing map at 0x63aa00.
> [Wed Jun 10 12:56:10 2009].600928 msDrawMap(): Layer 0 (World), 49.215s
> [Wed Jun 10 12:56:10 2009].601264 msDrawLabelCache():
> [Wed Jun 10 12:56:10 2009].629768 msDrawMap(): Drawing Label Cache, 0.029s
> [Wed Jun 10 12:56:10 2009].629802 msDrawMap() total time: 49.246s
> [Wed Jun 10 12:56:10 2009].655105 msSaveImage() total time: 0.025s
> [Wed Jun 10 12:56:10 2009].655601 mapserv request processing time (loadmap
> not incl.): 49.272s
> [Wed Jun 10 12:56:10 2009].655623 msFreeMap(): freeing map at 0x63aa10.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
