[mapserver-dev] Shapefile goes from 1 sec to 90+ sec just
adding a labels!
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jun 15 12:22:25 EDT 2009
Did this test case materialize anywhere?
Steve
>>> On 6/10/2009 at 12:09 PM, in message
<30fe546d0906101009i38f0e4fuf6e7bc7e2c9e158c at mail.gmail.com>, Paul Ramsey
<pramsey at cleverelephant.ca> wrote:
> That's awesome. Want to roll up the data/symbols/fonts into a zip file?
> P
> On Wed, Jun 10, 2009 at 10:07 AM, Stephen
> Woodbridge<woodbri at swoodbridge.com> wrote:
>> Hi all,
>> I have run into a very bazaar problem with a shapefile going from 1 second
>> render times to ~50 second render times just for the geometry, not the label
>> cache when I add labels to the layer.
>> I can reproduce this with just one layer and one shapefile.
>> Has anyone else run into anything like this?
>> -Steve
>> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> MAP
>> MAXSIZE 4000
>> SIZE 800 800
>> SHAPEPATH "/u/data/data/Jamaica-900913"
>> SYMBOLSET "/u/data/data/Jamaica-900913/symbols/symbols.sym"
>> FONTSET "/u/data/data/Jamaica-900913/symbols/fontset.txt"
>> IMAGECOLOR "#80B1D3"
>> IMAGETYPE agg
>> EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
>> UNITS METERS
>> DEBUG 10
>> CONFIG MS_ERRORFILE "stderr"
>> OUTPUTFORMAT
>> NAME agg
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> MIMETYPE "image/png"
>> IMAGEMODE RGB
>> FORMATOPTION "INTERLACE=false"
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> END
>> WEB
>> METADATA
>> wms_srs "epsg:900913"
>> labelcache_map_edge_buffer "-10"
>> wms_title "jamaica data"
>> END
>> END
>> LAYER
>> NAME "World"
>> GROUP "cb"
>> STATUS DEFAULT
>> TYPE POLYGON
>> DATA "world/world"
>> CLASSITEM "COLOR"
>> LABELITEM "NAME"
>> CLASS
>> EXPRESSION "1"
>> STYLE
>> COLOR "#99B3FF"
>> OUTLINECOLOR "#888888"
>> END
>> LABEL
>> TYPE TRUETYPE FONT "arial" SIZE 7 COLOR "#010101" PARTIALS FALSE
>> OUTLINEWIDTH 3
>> PRIORITY 8
>> BUFFER 4 POSITION CC MINDISTANCE 250 MINFEATURESIZE 10
>> END
>> END
>> CLASS
>> EXPRESSION "2"
>> STYLE
>> COLOR "#B3FF99"
>> END
>> LABEL
>> OUTLINEWIDTH 3
>> PRIORITY 8
>> END
>> END
>> CLASS
>> EXPRESSION "3"
>> STYLE
>> COLOR "#FFE699"
>> END
>> LABEL
>> OUTLINEWIDTH 3
>> PRIORITY 8
>> END
>> END
>> CLASS
>> EXPRESSION "4"
>> STYLE
>> COLOR "#FFB399"
>> END
>> LABEL
>> OUTLINEWIDTH 3
>> PRIORITY 8
>> END
>> END
>> CLASS
>> EXPRESSION "5"
>> STYLE
>> COLOR "#99FFB3"
>> END
>> LABEL
>> OUTLINEWIDTH 3
>> PRIORITY 8
>> END
>> END
>> END
>> END
>> Here is the log of just zooming out:
>> [Wed Jun 10 12:53:35 2009].323025 msDrawMap(): Layer 0 (World), 0.422s
>> [Wed Jun 10 12:53:35 2009].323329 msDrawLabelCache():
>> labelcache_map_edge_buffer = -10
>> [Wed Jun 10 12:53:35 2009].336325 msDrawMap(): Drawing Label Cache, 0.013s
>> [Wed Jun 10 12:53:35 2009].336355 msDrawMap() total time: 0.438s
>> [Wed Jun 10 12:53:35 2009].357835 msSaveImage() total time: 0.021s
>> [Wed Jun 10 12:53:35 2009].358140 mapserv request processing time (loadmap
>> not incl.): 0.460s
>> [Wed Jun 10 12:53:35 2009].358160 msFreeMap(): freeing map at 0x63aa00.
>> [Wed Jun 10 12:53:36 2009].994979 msDrawMap(): Layer 0 (World), 0.786s
>> [Wed Jun 10 12:53:36 2009].995292 msDrawLabelCache():
>> [Wed Jun 10 12:53:37 2009].7982 msDrawMap(): Drawing Label Cache, 0.013s
>> [Wed Jun 10 12:53:37 2009].8014 msDrawMap() total time: 0.801s
>> [Wed Jun 10 12:53:37 2009].29497 msSaveImage() total time: 0.021s
>> [Wed Jun 10 12:53:37 2009].29769 mapserv request processing time (loadmap
>> not incl.): 0.823s
>> [Wed Jun 10 12:53:37 2009].29789 msFreeMap(): freeing map at 0x63aa00.
>> [Wed Jun 10 12:53:41 2009].780255 msDrawMap(): Layer 0 (World), 3.827s
>> [Wed Jun 10 12:53:41 2009].780566 msDrawLabelCache():
>> [Wed Jun 10 12:53:41 2009].795910 msDrawMap(): Drawing Label Cache, 0.015s
>> [Wed Jun 10 12:53:41 2009].795941 msDrawMap() total time: 3.845s
>> [Wed Jun 10 12:53:41 2009].818499 msSaveImage() total time: 0.023s
>> [Wed Jun 10 12:53:41 2009].818785 mapserv request processing time (loadmap
>> not incl.): 3.868s
>> [Wed Jun 10 12:53:41 2009].818805 msFreeMap(): freeing map at 0x63aa10.
>> [Wed Jun 10 12:54:40 2009].258306 msDrawMap(): Layer 0 (World), 56.436s
>> [Wed Jun 10 12:54:40 2009].258634 msDrawLabelCache():
>> [Wed Jun 10 12:54:40 2009].293897 msDrawMap(): Drawing Label Cache, 0.035s
>> [Wed Jun 10 12:54:40 2009].293931 msDrawMap() total time: 56.474s
>> [Wed Jun 10 12:54:40 2009].320803 msSaveImage() total time: 0.027s
>> [Wed Jun 10 12:54:40 2009].321088 mapserv request processing time (loadmap
>> not incl.): 56.501s
>> [Wed Jun 10 12:54:40 2009].321110 msFreeMap(): freeing map at 0x63aa00.
>> [Wed Jun 10 12:56:10 2009].600928 msDrawMap(): Layer 0 (World), 49.215s
>> [Wed Jun 10 12:56:10 2009].601264 msDrawLabelCache():
>> [Wed Jun 10 12:56:10 2009].629768 msDrawMap(): Drawing Label Cache, 0.029s
>> [Wed Jun 10 12:56:10 2009].629802 msDrawMap() total time: 49.246s
>> [Wed Jun 10 12:56:10 2009].655105 msSaveImage() total time: 0.025s
>> [Wed Jun 10 12:56:10 2009].655601 mapserv request processing time (loadmap
>> not incl.): 49.272s
>> [Wed Jun 10 12:56:10 2009].655623 msFreeMap(): freeing map at 0x63aa10.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
