Fwd: [mapserver-dev] Shapefile goes from 1 sec to 90+ sec just adding
a labels!
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 15 17:33:48 EDT 2009
If I take out the if(isOuterRing(p, i)) test from
getPolygonCenterOfGravity the speed goes up by a factor of 30 and the
result looks the same. Since getPolygonCenterOfGravity only uses the
biggest ring, and holes are going to be smaller than the biggest ring,
I think this is a reasonable thing to do.
P
---------- Forwarded message ----------
Date: Mon, Jun 15, 2009 at 2:00 PM
Subject: Re: [mapserver-dev] Shapefile goes from 1 sec to 90+ sec just
adding a labels!
To: Stephen Woodbridge <woodbri at swoodbridge.com>
and the relevant stack trace for msPointInPolygon seems to be
msPolygonLabelPoint calls
getPolygonCenterOfGravity calls
isOuterRing calls
msPointInPolygon
and it does so because shapeObj doesn't provide any guarantees about
ring order, so ring order must always be checked.
Also, because the test polygons are both huge (number of vertices)
*and* have lots of parts, this loop in getPolygonCenterOfGravity is
pretty rough:
for(i=0; i<p->numlines; i++) {
if(isOuterRing(p, i)) {}
It's actually O(N^2) against the number of rings, since isOuterRing
itself runs through each ring (less one). So the high number of rings
in this test data is really exercising this.
pramsey=# select name,nrings(the_geom) from world order by nrings desc;
name | nrings
Canada | 18376
Finland | 8656
United States | 7978
Norway | 7404
Greenland | 7091
Sweden | 5464
Chile | 5148
Indonesia | 4267
Russia | 3991
Australia | 3320
China | 2161
Philippines | 1662
Cuba | 1557
Japan | 1515
Brazil | 1465
South Korea | 1332
Burma | 1166
United Kingdom | 1132
The Bahamas | 1111
Mexico | 1072
Iceland | 1018
That's right: blame Canada.
P.
On Mon, Jun 15, 2009 at 1:06 PM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
> Shark tells me that 83% of cycles are spend in msPointInPolygon.
> PostGIS tells me that these are some pretty damn big polygons:
> pramsey=# select npoints(the_geom) from world order by npoints desc;
> npoints
> 586416
> 265758
> 262693
> 201410
> 165279
> 164432
> 135854
> 117943
> 81531
> 70580
> 66749
> 62417
> 53843
> 53641
> 42864
> 41904
> Match made in hell.
> P
> On Mon, Jun 15, 2009 at 12:01 PM, Stephen
> Woodbridge<woodbri at swoodbridge.com> wrote:
>> http://trac.osgeo.org/mapserver/ticket/3053
>> Steve Lime wrote:
>>> Did this test case materialize anywhere?
>>> Steve
>>>>>> On 6/10/2009 at 12
