[mapserver-dev] Beginning Mapserver & sql server 2008
Wesley
wesmota at gmail.com
Tue Jun 30 17:17:26 EDT 2009
Hi all,
It's my first time with mapserver, and I'm trying to use a map file
connected with sql server 2008. Mapserver is generating a blank image.
I think there is something wrong with my map file below.
Do you have any examples or tutorial about it?
Thanks,
__________________________________________________________
MAP
NAME "sample"
STATUS ON
SIZE 400 300
IMAGETYPE gif
EXTENT -66.00 -22.00 -44.00 -9.00
UNITS DD
# Start of web interface definition
WEB
TEMPLATE "D:\ms4w\Apache\htdocs\testesql.html"
IMAGEPATH "D:\ms4w\tmp\ms_tmp\"
IMAGEURL "/tmp/"
END
LAYER
NAME "Camada1"
CONNECTIONTYPE PLUGIN
PLUGIN "D:\ms4w\plugins\msplugin_mssql2008.dll"
CONNECTION "server=luzon2\sqlexpress;uid=sa;pwd=senha1234;database=TESTE;Integrated
Security=false"
DATA "geom from lixo"
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
COLOR 0 0 255
WIDTH 8
END
END
END
END
