[mapserver-dev] Beginning Mapserver & sql server 2008
Brent Fraser bfraser at geoanalytic.com
Tue Jun 30 17:32:54 EDT 2009
Wesley,
   Try setting:
    IMAGEURL "/ms_tmp/"
And to test the rest of your map file, you may want to try Mapserver's
command-line companion tool shp2img (ms4w puts it in \ms4w\Apache\cgi-bin):
Best Regards,
Brent Fraser
Wesley wrote:
> Hi all,
> It's my first time with mapserver, and I'm trying to use a map file
> connected with sql server 2008. Mapserver is generating a blank image.
> I think there is something wrong with my map file below.
> Do you have any examples or tutorial about it?
> Thanks,
> __________________________________________________________
> MAP
>  NAME "sample"
>  STATUS ON
>  SIZE 400 300
>  IMAGETYPE gif
>  EXTENT -66.00 -22.00 -44.00 -9.00
>  UNITS DD
> # Start of web interface definition
>  WEB
>     TEMPLATE "D:\ms4w\Apache\htdocs\testesql.html"
>     IMAGEPATH "D:\ms4w\tmp\ms_tmp\"
>     IMAGEURL "/tmp/"
>  END
>  LAYER
>   NAME "Camada1"
>   CONNECTIONTYPE PLUGIN
>   PLUGIN "D:\ms4w\plugins\msplugin_mssql2008.dll"
>   CONNECTION "server=luzon2\sqlexpress;uid=sa;pwd=senha1234;database=TESTE;Integrated
> Security=false"
>   DATA "geom from lixo"
>   TYPE POLYGON
>   STATUS ON
>    PROJECTION
>       "init=epsg:4326"
>    END
>    CLASS
>      STYLE
>        COLOR 0 0 255
>        WIDTH 8
>      END
>    END
>  END
> END
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
