[mapserver-dev] MS-RFC-55: Improving control of output resolution
Havard Tveite
havard.tveite at umb.no
Wed Mar 11 11:19:00 EDT 2009
Excellent!
I am very happy to observe that, as a side-effect, support
for consistent symbol scaling (as suggested in RFC45 -
Symbology, Labeling, and Cartography Improvements) now is
gaining support. :-)
Håvard Tveite
Daniel Morissette wrote:
> RFC 55 has been updated with the list of affected parameters. the new
> version should be online in the next hour at:
> http://www.mapserver.org/development/rfc/ms-rfc-55.html
> I'll leave another day for comments and will call for a vote later this
> week if there are no more changes required.
> Daniel
> thomas bonfort wrote:
>> It will be up to the rendering code to decide what is scaled or not.
>> The RFC should probably go into more detail for exactly which
>> parameters will be affected by the scaling. Other candidates that come
>> to mind are:
>> * offsets (line, point, polygon)
>> * pattern (line)
>> * outlinewidth (labels)
>> * shadowsize, background-shadow-size (labels)
>> * buffer around labels (colision) ?
>> * minfeaturesize, mindistance (labels)
>> thomas
>> On Mon, Mar 9, 2009 at 17:58, Paul Spencer <pspencer at dmsolutions.ca> wrote:
>>> Daniel,
>>> will this be applied to the gap in symbols?
>>> Paul
>>> On 9-Mar-09, at 3:48 PM, Daniel Morissette wrote:
>>>> Following a discussion at the code sprint this morning, I have prepared MS
>>>> RFC 55 that documents the solution that we came up with for improving
>>>> control of output resolution when printing. We realize that there were
>>>> interesting ideas proposed on the -dev list in the thread on this topic a
>>>> couple of weeks ago (like the use of point units for instance), but we chose
>>>> this approach because it is the most straightforward for users and requires
>>>> very little change to the source and to existing apps/mapfiles.
>>>> The RFC is going to be online within the next hour at:
>>>> Daniel
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> Paul Spencer
>>> Chief Technology Officer
>>> DM Solutions Group Inc
>>> http://research.dmsolutions.ca/
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
