[mapserver-dev] MS-RFC-55: Improving control of output resolution
Daniel Morissette
dmorissette at mapgears.com
Tue Mar 10 11:47:17 EDT 2009
RFC 55 has been updated with the list of affected parameters. the new
version should be online in the next hour at:
http://www.mapserver.org/development/rfc/ms-rfc-55.html
I'll leave another day for comments and will call for a vote later this
week if there are no more changes required.
Daniel
thomas bonfort wrote:
> It will be up to the rendering code to decide what is scaled or not.
> The RFC should probably go into more detail for exactly which
> parameters will be affected by the scaling. Other candidates that come
> to mind are:
> * offsets (line, point, polygon)
> * pattern (line)
> * outlinewidth (labels)
> * shadowsize, background-shadow-size (labels)
> * buffer around labels (colision) ?
> * minfeaturesize, mindistance (labels)
> thomas
> On Mon, Mar 9, 2009 at 17:58, Paul Spencer <pspencer at dmsolutions.ca> wrote:
>> Daniel,
>> will this be applied to the gap in symbols?
>> Paul
>> On 9-Mar-09, at 3:48 PM, Daniel Morissette wrote:
>>> Following a discussion at the code sprint this morning, I have prepared MS
>>> RFC 55 that documents the solution that we came up with for improving
>>> control of output resolution when printing. We realize that there were
>>> interesting ideas proposed on the -dev list in the thread on this topic a
>>> couple of weeks ago (like the use of point units for instance), but we chose
>>> this approach because it is the most straightforward for users and requires
>>> very little change to the source and to existing apps/mapfiles.
>>> The RFC is going to be online within the next hour at:
>>> Daniel
>>> Daniel Morissette
>>> http://www.mapgears.com/
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://research.dmsolutions.ca/
Daniel Morissette
