[mapserver-dev] graphics branch merge
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Mar 11 18:00:40 EDT 2009
Do you still want to do this? If we can still use the existing AGG and GD code then I'm
+1 on the merge...
Steve
>>> On 3/8/2009 at 1:38 PM, in message
<d2b988930903081138j36e92de2y6a2421fc6b89fdad at mail.gmail.com>, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> I've updated
> http://trac.osgeo.org/mapserver/wiki/UnifyingTheRenderingInterfaces
> with a couple of notes on the common rgba pixel format that will be
> used by the plugin renderers (except for GD), to prepare for
> integration with the raster handling code.
> The graphics branch has been modified so the cairo and opengl code is
> disabled by default, so it should compile without the need for those
> libs.
> Could we have a vote on wether I can merge this branch back into trunk
> so further development on the plugin renderers can take place there?
> tks,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
