[mapserver-dev] graphics branch merge
thomas bonfort
thomas.bonfort at gmail.com
Wed Mar 11 18:20:31 EDT 2009
Probably not, I find the risk of breakage is a bit too high. I'll try
and implement the ideas we discussed at the sprint, and come back with
a formal rfc for the merge once things are stable enough.
thomas
On Wed, Mar 11, 2009 at 18:00, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Do you still want to do this? If we can still use the existing AGG and GD code then I'm
> +1 on the merge...
> Steve
>>>> On 3/8/2009 at 1:38 PM, in message
> <d2b988930903081138j36e92de2y6a2421fc6b89fdad at mail.gmail.com>, thomas bonfort
> <thomas.bonfort at gmail.com> wrote:
>> I've updated
>> http://trac.osgeo.org/mapserver/wiki/UnifyingTheRenderingInterfaces
>> with a couple of notes on the common rgba pixel format that will be
>> used by the plugin renderers (except for GD), to prepare for
>> integration with the raster handling code.
>> The graphics branch has been modified so the cairo and opengl code is
>> disabled by default, so it should compile without the need for those
>> libs.
>> Could we have a vote on wether I can merge this branch back into trunk
>> so further development on the plugin renderers can take place there?
>> tks,
>> thomas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
