[mapserver-dev] Vote for MS-RFC-55: Improve control of output
resolution
Brent Fraser
bfraser at geoanalytic.com
Mon Mar 16 15:06:45 EDT 2009
Bob,
You are right. For RFC-55, the user would change the RESOLUTION and a scaling would automatically be applied to the appropriate objects.
In my proposed solution, if MapServer's default size unit was changed to be POINTS (and the user had not expicitly set the LAYER's units to PIXELS), the effect would be the same.
Hmmm, maybe Daniel's solution IS easier to document/explain (and code). We just need to come up with a better word than DEFRESOLUTION.
Brent
Bob Basques wrote:
> All,
> I think the arguement is to set the default to handle the scaling automatically instead of requiriung the user to enter anything, unless they really do "NOT" want the printed output to look like the screen output. IOW, no edits would be needed, unless the desire was to do something special, IE, not to edit something just to get to a default point.
> Or am I reading too much between the lines?
> bobb
>>>> thomas bonfort <thomas.bonfort at gmail.com> 03/16/09 1:47 PM >>>
>> New User: "I changed my RESOLUTION to be 300 dpi so I could print my map,
>> but the text is now too small!"
> this is one of the points that's addressed by this rfc. The text would
> only be rendered tiny in this case only if the new user had
> explicitely set defresolution to 300, which isn't likely.
> that's what's kind of nice with this way of doing, as by default you
> just have to set resolution to something different than 72 and all
> your symbology (and labels) is scaled accordingly.
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
