[mapserver-dev] INCLUDE '...' before MAP gives "Unknown identifier. First token must be MAP..."
David Fuhry dfuhry at acm.org
Thu May 7 21:55:18 EDT 2009
Some recent update seems to have broken the ability to have INCLUDEs in
a mapfile before the MAP clause.  I normally use an INCLUDE which brings
in a bunch of OUTPUTFORMATs, before beginning the MAP tag.
Mapfile:
INCLUDE "outputformat.map.frag"
MAP
END
gives:
msLoadMap(): Unknown identifier. First token must be MAP, this doesn't
look like a mapfile.
I moved to svn HEAD from a build made a few months ago; it was fine
then.  Would appreciate a pointer to the bug #, if this problem is known.
-Dave
