[mapserver-dev] INCLUDE '...' before MAP gives "Unknown identifier. First token must be MAP..."
David Fuhry dfuhry at acm.org
Thu May 7 22:24:09 EDT 2009
FYI, the attached ill-advised patch, did work for me as a quick-fix.
I commented out the part of the parsers which fails if the the MAP and
SYMBOLSET tokens are not yet found.
-Dave
David Fuhry wrote:
> Some recent update seems to have broken the ability to have INCLUDEs in
> a mapfile before the MAP clause.  I normally use an INCLUDE which brings
> in a bunch of OUTPUTFORMATs, before beginning the MAP tag.
> Mapfile:
> INCLUDE "outputformat.map.frag"
> MAP
> END
> gives:
> msLoadMap(): Unknown identifier. First token must be MAP, this doesn't
> look like a mapfile.
> I moved to svn HEAD from a build made a few months ago; it was fine
> then.  Would appreciate a pointer to the bug #, if this problem is known.
> -Dave
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090507/4cc8e049/ill_advised_mapfile_mapsymbol.v1.bin
