[mapserver-dev] raster rewind
David Fuhry dfuhry at acm.org
Fri May 15 19:42:55 EDT 2009
Updated patch, with some bug fixes.  All the previous caveats about its
limited scope, still apply.
-Dave
David Fuhry wrote:
> I just hit a savepoint working on an experimental patch to mapdraw.c,
> which I'm calling "raster rewind".  It's not intended for general use.
> When dealing with a patchwork of raster imagery, where a hi-res layer
> may cover up a broader low-res layer, then the patch can help to discard
> unnecessary low-res layers.  I post it, in case someone finds it
> interesting.
> The idea is that if a hi-res layer renders a fully opaque image, then it
> was not necessary to process any lower-level layers that preceded it. To
> determine the former condition, visible raster layers are first iterated
> through *backwards*, each rendered into its own temporary image buffer.
> If, when iterating backwards, a layer renders a fully opaque image, then
> we can start mapfile layer processing at that index, rather than 0.
> Intuitively, that layer would cover any previous layers' renderings.
> Later, I intend to implement a transparency threshold, rather than an
> all-or-nothing opaqueness measure, since some of our raster layers have
> just a few (~ 0.0002%) pixels which match the OFFSITE (transparent) color.
> This patch does not handle skipped layers which may have rendered labels.
> -Dave
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090515/fc590e35/raster_rewind.v5-0001.bin
