[mapserver-dev] SOS responseFormat
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Tue May 19 09:34:57 EDT 2009
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> bartvde at osgis.nl
> Sent: Tuesday, 19 May 2009 05:05
> To: mapserver-dev at lists.osgeo.org
> Subject: [mapserver-dev] SOS responseFormat
> Hi list,
> these are my first steps into the SOS field. I am trying to
> write an SOS client in OpenLayers based on the work from Till
> Adams, and I am testing
> against:
> -Mapserver
> -52North
> However, it seems there is already a discrepancy between the
> two implementations about the correct value of responseFormat.
> 52North wants (note the quotes around subtype value)
> text/xml;subtype="om/1.0.0"
> Mapserver wants:
> text/xml; subtype=om/1.0.0
Looks like your right.  Can you open a ticket on this one and assign to
myself?
> If I look at the OGC spec it seems 52North is more right.
> Although 52North cannot deal with a space after the ; which
> seems a bit weird to me. The spec examples also use a space
> in between.
OGC Common 1.1.0 perscribes the space in between, so we're keeping to
spec for that part of the MIME type definition.
> Any SOS expert willing to comment on this? Since right now
> this is breaking interoperability :-)
> TIA.
> Best regards,
> Bart
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
