[mapserver-dev] Labeling enhancements
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 28 10:32:03 EDT 2009
I like the overall idea. What about using MAXDISTANCE as the repeat
keyword, but REPEATDISTANCE might be a little more intuitive.
-Steve W
Daniel Morissette wrote:
> Steve Lime wrote:
>> What about just using MINDISTANCE parameter and simply making a
>> "REPEAT YES|NO" parameter? Depending on how you implemented (one
>> label with multiple label points vs. multiple labels) you'd have to deal
>> with that parameter anyway. REPEAT would trigger multiple labels with
>> MINDISTANCE defining the distance between them on the line but also
>> as the crow flies. Perhaps too simple.
> I thought of that too, but if we're adding a keyword anyway, I figured
> we might as well use it to provide the flexibility of using a repeat
> interval different from MINDISTANCE. In tuning the look of their maps,
> users may want to play with repeat distance larger than mindistance and
> vice-versa... I'm not convinced that there is a single way to achieve
> the best results, so I thought it may be best to let the mapfile writers
> decide which values they want for the repeat interval and for mindistance.
> With respect to implementation, we'd do it by feeding multiple
> independent labels into the cache, so they are all treated independently
> by the feature cache.
> Daniel
