[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
Normand Savard nsavard at mapgears.com
Mon Nov 2 14:37:24 EST 2009
teeschke wrote:
> Dear Jeff, Normand
> nearly two month went and nothing changed on ms4w?
> version 3.0 beta7 is still the recent version and includes the bug number
> 2094
Daniel,
Only Jeff can debug what maybe the cause of this problem.  I did as much
digging as could to provide more info to Jeff but we need to play with
the build kit to push the investigation further on.
http://bugzilla.maptools.org/show_bug.cgi?id=2094
Norm
> best regards,
> Daniel
> Jeff McKenna wrote:
>> Steve Lime wrote:
>>> I will... In your version line there's 'SUPPORTS=RGBA_PNG' which is the
>>> signature for
>>> the experimental PNG support. Wonder what versions are used by mapserver
>>> and then
>>> GD? Does IMAGETYPE JPEG work for you?
>> Steve,
>> Older MS4W versions are fine, so I guess you are right, it must be some
>> conflict in GD and MapServer.  Darn.
>> -jeff
>> Jeff McKenna
>> FOSS4G Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
