[mapserver-dev] MS 5.4 - Python-MS - queryByRect strange behavior
Christian Jauvin cjauvin at gmail.com
Mon Nov 9 14:08:52 EST 2009
Hi Steve,
In a previous message I sent a very simple Python script along with a
mapfile, that showed the problem (independtly of MS4W). Did you
receive it? Both files were attached to my message.
But I also found earlier today that the MS 5.6 beta 5 patch (for MS4W)
solved this particular problem..
Thanks,
Christian
On Mon, Nov 9, 2009 at 1:55 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> A small test case will really help if you can create one that way we can try independently
> of MS4W. As I read this it seems that you're doing a rect query on inline shapes. I don't
> recall if that code changed a bit in 5.4 or not. Perhaps Tamas can confirm.
> Steve
>>>> On 11/6/2009 at 12:00 PM, in message
> <aa5471510911061000v380ab8fbld95a294e4b784496 at mail.gmail.com>, Christian Jauvin
> <cjauvin at gmail.com> wrote:
>> Hi everyone,
>> I am currently developing a Python-MapScript based web-mapping
>> framework (http://dracones.surveillance.mcgill.ca) that worked fairly
>> well with earlier versions of MS (MS4W < 3 on Windows, and
>> package-based MS ~ 5.2 on Linux). This week I started playing with
>> Python 2.6 (looking, among other things, to port my framework from
>> mod_python to WSGI), and so it lead me to the latest beta of MS4W,
>> which I read has a version of Python-MS built for it. I am currently
>> using the Beta 7 of MS4W 3. I originally posted this to the MS4W-users
>> list only, suspecting that my problem was specific to it, but I was
>> then advised to post here as well, as it could point to a deeper MS
>> issue.
>> I have noticed a strange behavior with the queryByRect function,
>> different than what was before: when I programmatically add features
>> to a point layer and then try to retrieve a subset of them with
>> queryByRect, getNumResults gives the correct number of retrieved
>> features, but then the set of shapes returned by
>> layer.getFeature(layer.getResult(i).shapeindex) is not right. The best
>> way to explain the problem is this example: when I query for three
>> very distinct features, what I get is this:
>>  [<mapscript.shapeObj; proxy of <Swig Object of type 'shapeObj *' at
>> 0x01EC71E0> >,
>> 0x01EC71C0> >,
>> 0x01EC71E0> >]
>> The first and third objects seem to be the same, according to their
>> pointers. No matter what query I try to perform, there is always a
>> similar problem occurring: some pointers seem to be pointing to shared
>> features, whereas they shouldn't (at least from what I understand).
>> I understand that this problem description may not be terribly helpful
>> since it may be hard to reproduce, but given that it would take time
>> to abstract away the suspicious code in my framework, I thought that I
>> would go for the high-level first, in case I am missing something
>> obvious. I am ready to try building a more thorough test case and file
>> it, if needed however.
>> Thanks in advance for any help,
>> Christian
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
