[mapserver-dev] PostGIS performance
Paul Ramsey pramsey at cleverelephant.ca
Fri Nov 27 13:57:55 EST 2009
Like, are you routinely logging at that level of verbosity? That would
do it, since the new version does have a lot more logging available.
P.
On Fri, Nov 27, 2009 at 10:55 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> There is almost certainly some other confounding variable in play.
> There was a *slight* performance penalty for moving off binary
> cursors, but not something people would necessarily notice.
> P.
> On Fri, Nov 27, 2009 at 9:48 AM, Bart van den Eijnden <bartvde at osgis.nl> wrote:
>> Hi list,
>> somebody reported to me that using Mapserver 5.1 dev on PostGIS compared to 5.4.2 the latter was a lot slower then the first one with maps.
>> Is this to be expected of the binary cursor rewrite Paul did 1 year ago? Or should it be the same performance?
>> TIA.
>> FWTools (MS 5.1-dev):
>> msPOSTGISLayerParseData: unique column = OID, srid='', geom_column_name = the_geom, table_name=bebouwdekom
>> query_string_0_6:DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from bebouwdekom WHERE the_geom && setSRID('BOX3D(107000 435852.25375626,175000 481147.74624374)'::BOX3D, find_srid('','bebouwdekom','the_geom') )
>> msPOSTGISLayerFreeItemInfo called
>> msPOSTGISLayerClose datastatement: the_geom from bebouwdekom
>> msPOSTGISLayerClose -- closing query_result
>> MS 5.4.2:
>> msPostGISParseData: unique_column=oid, srid=, geom_column_name=the_geom, table_name=bebouwdekom
>> msPostGISBuildSQL called.
>> msPostGISBuildSQLItems called.
>> msPostGISBuildSQLFrom called.
>> msPostGISBuildSQLWhere called.
>> msPostGISBuildSQLSRID called.
>> msPostGISBuildSQLBox called.
>> msPostGISLayerWhichShapes query: select encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'base64') as geom,"oid" from bebouwdekom where the_geom && GeomFromText('POLYGON((107000 435852.25375626,107000 481147.74624374,175000 481147.74624374,175000 435852.25375626,107000 435852.25375626))',find_srid('','bebouwdekom','the_geom'))
>> msPostGISLayerWhichShapes got 276 records in result.
>> msPostGISLayerNextShape called.
>> msPostGISReadShape called.
>> msPostGISLayerFreeItemInfo called.
>> msPostGISLayerClose called: the_geom from bebouwdekom
>> Compilation options:
>> ./configure --with-agg=../agg-2.5 --with-freetype --with-proj --with-curl --with-experimental-png --with-geos --with-ogr --with-gdal --with-postgis --with-wfs --with-wmsclient --with-wfsclient --with-fastcgi
>> $ pg_config|grep VERSION
>> VERSION = PostgreSQL 8.1.17
>> Version info:
>> MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> FWTools 2.0.6:
>> MapServer version 5.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> Best regards,
>> Bart_______________________________________________
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
