[mapserver-dev] help:thanks,create maps on the fly without
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Oct 3 09:13:20 EDT 2009
Tamas Szekeres wrote:
> I don't have any PHP examples out there, as I'm using C# primarily in
> my practice. However the PHP object model (refer to
> http://mapserver.org/mapscript/php/index.html) is pretty much the same
> so converting the code would be straightforward.
> Best regards,
> Tamas
> 2009/10/3 Rui Jianxun <gis at shnu.edu.cn>:
>> hi Tamas Szekeres,
>> The address
>> (http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapscript/csharp/examples/inline.cs
>> )you showed to me is using c#+mapscript to draw layers with several classes
>> defined in the programming environment. This is very flexible for programmer
>> to draw thematic map what  they like to. But in the same address,in PHP
>> MODULES,i donot find the examples using PHP to relize the same
>> functinal,because  the later(PHP) would read mapfile,but the former
>> (C#) need not to read mapfile.
>> Would you like to give me some examples using PHP nor c# that need not read
>> mapfiles?
>> Best Regards,
>> Rui jx
>>> Today&apos;s Topics:
>>>   1. Re: help:create maps on the fly without having a map     file
>>>      (Tamas Szekeres)
You might also check the PHPMapScript wiki page
(http://trac.osgeo.org/mapserver/wiki/PHPMapScript).  You can also add
your own working examples there for others.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
