[mapserver-dev] help:thanks,create maps on the fly without
Tamas Szekeres
szekerest at gmail.com
Sat Oct 3 07:18:04 EDT 2009
I don't have any PHP examples out there, as I'm using C# primarily in
my practice. However the PHP object model (refer to
http://mapserver.org/mapscript/php/index.html) is pretty much the same
so converting the code would be straightforward.
Best regards,
Tamas
2009/10/3 Rui Jianxun <gis at shnu.edu.cn>:
> hi Tamas Szekeres,
> The address
> (http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapscript/csharp=
/examples/inline.cs
> )you showed to me is using c#+mapscript to draw layers with several class=
es
> defined in the programming environment. This is very flexible for program=
mer
> to draw thematic map what they like to. But in the same address,in PHP
> MODULES,i donot find the examples using PHP to relize the same
> functinal,because the later(PHP) would read mapfile,but the former
> (C#) need not to read mapfile.
> Would you like to give me some examples using PHP nor c# that need not re=
ad
> mapfiles?
> Best Regards,
> Rui jx
>>Today's Topics:
>> 1. Re: help:create maps on the fly without having a map file
>> (Tamas Szekeres)
>>Message: 1
>>Date: Fri, 2 Oct 2009 17:01:35 +0200
>>From: Tamas Szekeres <szekerest at gmail.com>
>>Subject: Re: [mapserver-dev] help:create maps on the fly without
>> having a map file
>>To: ??? <ruijianxun at 126.com>
>>Cc: mapserver-dev <mapserver-dev at lists.osgeo.org>
>>Message-ID:
>> <f3b73b7d0910020801l7648f71bvd715a59128538853 at mail.gmail.com>
>>Content-Type: text/plain; charset=3DGB2312
>>Hi,
>>MapScript provides the object model (a couple of classes with
>>properties and methods) for setting up your map configuration from
>>scratch. You would normally require to create a map object (mapObj)
>>add layers and set up the styles and symbology for each layer. You
>>could then render the map into an image object or you could optionally
>>save your map configuration to a mapfile for later use.
>>Here is an example written in C# to set up a map configuration
>>programmatically:
>>http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapscript/csharp/=
examples/inline.cs
>>This example creates the shapes for the layer programmatically as well.
>>Best regards,
>>Tamas
>>2009/10/2 =DC=C7=BD=A8=D1=AB <ruijianxun at 126.com>:
>>> Hi everyone,
>>> I have found a paragraph in a book named <Web Mapping Illustrated-p>,as
>>> fllowing:
>>> "MapServer map files are still a key component to writing a MapScript-b=
ased
>>> application. If you have a map file ready to use, you can start accessi=
ng
>>> and manipulating it right away. However, a powerful feature of MapScrip=
t is
>>> the ability to create maps on the fly without having a map file. In thi=
s
>>> case, you can build your map from scratch".
>>> I donot understand that we can create maps on the fly without having a =
map
>>> file.Is mapserver can really work without mapfile,especially in the
>>> environment via PHP/MapScript or Python /MapScript ?
>>> Best Regards,
>>> Rui jx
>>> ________________________________
>>> =CD=F8=D2=D7=D3=CA=CF=E4=D3=C3=BB=A7=B9=BA=CE=EF=B6=C0=CF=ED=CF=D6=BD=
=F0=B7=B5=BB=B9
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>End of mapserver-dev Digest, Vol 21, Issue 3
