[mapserver-dev] MapServer 5.6.0-beta3 released
Havard Tveite havard.tveite at umb.no
Tue Oct 13 05:53:28 EDT 2009
Thomas Bonfort wrote:
> Havard,
> can you post your mapfile layer corresponding to those images?
Dear Thomas,
Here is the complete layer (you will find the two symbols "marsh_isom" and
"indistinctmarsh_isom" down there).
Håvard
   LAYER  # Kart - Polygons
     NAME o-kartpolygon
     GROUP "poly"
     STATUS OFF
     TYPE POLYGON
     CONNECTION "blabal"
     CONNECTIONTYPE postgis
     DATA "the_geom from (select oid, symbol, the_geom from okartpolygon order by sequence) as okart using unique oid using SRID=-1"
     METADATA
       "layer_title" "O-kart - polygoner"
       "legend_order" "1"
     END
     SYMBOLSCALEDENOM 2650
     PROJECTION
       "init=epsg:32633"
     END
     LABELITEM "symbol"
     CLASS
       NAME "Berg i dagen"
       EXPRESSION ([symbol] = 2120)
       STYLE
         COLOR 204 204 204
       END # style
     END # CLASS
     CLASS
       NAME "Dyrka mark"
       EXPRESSION ([symbol] = 4150)
       STYLE
         COLOR 255 186 54
       END # style
       STYLE
	symbol "dyrkamark"
	SIZE 80
         COLOR 0 0 0
       END # style
     END # CLASS
     CLASS
       NAME "Åpent lettløpt område"
       EXPRESSION ([symbol] = 4010)
       STYLE
         COLOR 255 186 54
       END # style
     END # CLASS
     CLASS
       NAME "Halvåpent lettløpt område"
       EXPRESSION ([symbol] = 4020)
       STYLE
         COLOR 255 186 54
	SIZE 8
       END # style
     END # CLASS
     CLASS
       NAME "Åpent område"
       EXPRESSION ([symbol] = 4030)
       STYLE
         COLOR 255 221 154
       END # style
     END # CLASS
     CLASS
       NAME "Halvåpent område"
       EXPRESSION ([symbol] = 4040)
       STYLE
         COLOR 255 205 114
       END # style
       STYLE
	symbol "halvapent"
	SIZE 100
	COLOR 255 255 255
       END # style
     END # CLASS
     CLASS
       NAME "Vegetasjon, nedsatt løpbarhet"
       EXPRESSION ([symbol] = 4060)
       STYLE
         COLOR 196 255 185
       END # style
     END # CLASS
     CLASS
       NAME "God sikt, nedsatt løpbarhet"
       EXPRESSION ([symbol] = 4070)
       STYLE
	symbol "vertgreen1"
	SIZE 84
         COLOR 61 255 23
       END # style
     END # CLASS
     CLASS
       NAME "Vegetasjon, dårlig løpbarhet"
       EXPRESSION ([symbol] = 4080)
       STYLE
         COLOR 139 255 116
       END # style
     END # CLASS
     CLASS
       NAME "God sikt, dårlig løpbarhet"
       EXPRESSION ([symbol] = 4090)
       STYLE
	symbol "vertgreen2"
	SIZE 42
         COLOR 61 255 23
       END # style
     END # CLASS
     CLASS
       NAME "Vegetasjon, ikke løpbar"
       EXPRESSION ([symbol] = 4100)
       STYLE
         COLOR 61 255 23
       END # style
     END # CLASS
     CLASS
       NAME "Bygning"
       EXPRESSION ([symbol] = 5260)
       STYLE
         COLOR 0 0 0
       END # style
     END # CLASS
     CLASS
       NAME "Forbudt område"
       EXPRESSION ([symbol] = 5270)
       STYLE
         COLOR 158 186 0
       END # style
     END # CLASS
     CLASS
       NAME "Vann"
       EXPRESSION ([symbol] = 3010 or [symbol] = 3020 )
       STYLE
         COLOR 0 0 255
       END # style
     END # CLASS
     CLASS
       NAME "Plass"
       EXPRESSION ([symbol] = 5290)
       STYLE
         COLOR 209 66  0
         #COLOR 230 120 0
         #COLOR 241 198 165
       #	COLOR 209 66 0 # Brun
       END # style
     END # CLASS
     CLASS
       NAME "Myr"
       EXPRESSION ([symbol] = 3100)
       STYLE
         COLOR 0 0 255
	SYMBOL "marsh_isom"
         MINSIZE 3
         SIZE 30
         #MAXSIZE 100
       END # style
     END # CLASS
     CLASS
       NAME "Farlig myr"
       EXPRESSION ([symbol] = 3090)
       STYLE
         COLOR 0 0 255
	SYMBOL "farligmyr"
         MINSIZE 3
         SIZE 50
         #MAXSIZE 100
       END # style
     END # CLASS
     CLASS
       NAME "Utydelig myr"
       EXPRESSION ([symbol] = 3110)
       STYLE
         COLOR 0 0 255
	SYMBOL "indistinctmarsh_isom"
         MINSIZE 3
         SIZE 60
         #MAXSIZE 200
       END # style
     END # CLASS
   END # LAYER # kart - polygons
> thanks,
> thomas
> On Tue, Oct 13, 2009 at 10:39, Havard Tveite <havard.tveite at umb.no> wrote:
>> Symbology change in 5.6.0?
>> In the list of changes for 5.6.0, I have not found any mention of
>> changes to symbol rendering.  However, from 5.4.2 to 5.6.0 beta3,
>> many of my vector symbols (polygon fills, points, "decorated"
>> lines) have been screwed up both for AGG and GD.
>> Something must have changed regarding how the "bounding box" of a
>> vector symbols is calculated when using it as tiles in a polygon
>> fill, and when placing point symbols.  It used to always use (0,0)
>> as the upper left corner, and the maximum x and y values as the
>> lower right corner.  This must be different now.  See the attached
>> images for an example of the resulting changes in rendering of
>> polygon fills.
>> The blue pattern that you see in the images are specified as
>> follows in the map file (exploiting the use of 0,0 as the upper
>> left corner):
>> SYMBOL
>>  NAME "marsh_isom"
>>  TYPE vector
>>  FILLED true
>>  POINTS
>>    0 0.6666666
>>    100 0.666666
>>    100 1
>>    0 1
>>    0 0.66666666
>>  END
>> END
>> SYMBOL
>>  NAME "indistinctmarsh_isom"
>>  TYPE vector
>>  FILLED true
>>  POINTS
>>    0 0.2
>>    0.45 0.2
>>    0.45 0.3
>>    0 0.3
>>    0 0.2
>>    -99 -99
>>    0.7 0.2
>>    1.15 0.2
>>    1.15 0.3
>>    0.7 0.3
>>    0.7 0.2
>>    -99 -99
>>    0.125 0.5
>>    1.025 0.5
>>    1.025 0.6
>>    0.125 0.6
>>    0.125 0.5
>>  END
>> END
>> This is a significant change, in my opinion, and users should
>> at least be warned.  Perhaps it even should wait to 6.0.
>> I do not know the exact nature of the change, but it could make
>> it more difficult to implement advanced vector symbols and
>> precise vector symbol placement.
>> In RFC 45, some of the symbology challenges and possible
>> solutions are discussed.  The introduction of a (SYMBOL)CENTER
>> tag could help a bit in reducing the consequences of the
>> current change, but would not address the polygon fill problem.
>> Should this be filed as a bug?
>> Håvard
>> Daniel Morissette wrote:
>>> MapServer 5.6.0-beta3 has just been released and is available for download
>>> at
>>>   http://mapserver.org/download.html OR
>>>   http://download.osgeo.org/mapserver/mapserver-5.6.0-beta3.tar.gz
>>> Please also keep an eye on the 5.4 to 5.6 Migration Guide where we will
>>> document migration issues for this release:
>>> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/MIGRATION_GUIDE.TXT
>>> Some great progress has been made since beta2 as you can tell from the
>>> list of fixes included at the end of this message, but there are a couple of
>>> tricky issues that are still being worked on, so we will have at least one
>>> other beta next week before we can have a release candidate.
>>> Once again, we need your help to ensure a high quality product so please
>>> help out by testing your applications with this new beta and reporting your
>>> results.
>>> Thanks for your help
>>> The MapServer development team.
>>> Version 5.6.0-beta3 (2009-10-07):
>>> - Fixed SDE layer seg fault (#3152)
>>> - Fixed placement of labels using ANGLE AUTO which were not always
>>> positioned
>>>   correctly (#3160)
>>> - Enable output of geometry in GML GetFeatureInfo if wms_geometries and
>>>   wms_geom_type are specified (#2989)
>>> - fix URN typo in mapwfs.c for urn:EPSG:geographicCRS:...
>>> - don't apply scalefactor to label outlines (#3157)
>>> - update namespaces and schema pointers (#2872)
>>> - add RFC49 and RFC40 keywords to copy functions (#2865)
>>> - minor fix to correct numberOfResults when maxfeatures is set in
>>>   mapfile (#2907)
>>> - Fixed possible crash with WFS GetFeature when no projection is specified
>>>   at the map level (#3129)
>>> - Fixed anchor point of vertically stacked bar graphs
>>> - Fixed TEXT property that cannot be removed in the CLASS object.
>>>   PHP/Mapscript (#3063)
>>> - Fixed use of minfeaturesize auto with curved labels (#3151)
>>> - Fixed msRemoveHashTable function when 2 keys have the same hash (#3146)
>>> - Fix raster thread deadlock condition on posix/linux (#3145)
>>> - Do not route thread debug output through msDebug which requires locking.
>>> - Fix WCS coverage metadata handling if size/resolution missing (#2683).
>>> - Fix WCS crash with use of datasets that aren't physical files (#2901).
>>> - Fix WCS failure with WCS 1.1 OGC URN (urn:ogc:def:crs:OGC::CRS84)
>>> (#3161).
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Håvard Tveite
>> Department of Mathematical Sciences and Technology, UMB
>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
Håvard Tveite
