[mapserver-dev] MapServer 5.6.0-beta3 released
Thomas Bonfort thomas.bonfort at camptocamp.com
Tue Oct 13 06:53:59 EDT 2009
There have been a few changes with scaledependant rendering since
beta3. could you try with the trunk version and report back, so we can
get any more fixes in before beta4?
thanks,
thomas
www.camptocamp.com
+33 5 16 57 01 02
On Tue, Oct 13, 2009 at 11:53, Havard Tveite <havard.tveite at umb.no> wrote:
> Thomas Bonfort wrote:
>> Havard,
>> can you post your mapfile layer corresponding to those images?
> Dear Thomas,
> Here is the complete layer (you will find the two symbols "marsh_isom" and
> "indistinctmarsh_isom" down there).
> Håvard
>  LAYER  # Kart - Polygons
>    NAME o-kartpolygon
>    GROUP "poly"
>    STATUS OFF
>    TYPE POLYGON
>    CONNECTION "blabal"
>    CONNECTIONTYPE postgis
>    DATA "the_geom from (select oid, symbol, the_geom from okartpolygon order
> by sequence) as okart using unique oid using SRID=-1"
>    METADATA
>      "layer_title" "O-kart - polygoner"
>      "legend_order" "1"
>    END
>    SYMBOLSCALEDENOM 2650
>    PROJECTION
>      "init=epsg:32633"
>    END
>    LABELITEM "symbol"
>    CLASS
>      NAME "Berg i dagen"
>      EXPRESSION ([symbol] = 2120)
>      STYLE
>        COLOR 204 204 204
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Dyrka mark"
>      EXPRESSION ([symbol] = 4150)
>      STYLE
>        COLOR 255 186 54
>      END # style
>      STYLE
>        symbol "dyrkamark"
>        SIZE 80
>        COLOR 0 0 0
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Åpent lettløpt område"
>      EXPRESSION ([symbol] = 4010)
>      STYLE
>        COLOR 255 186 54
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Halvåpent lettløpt område"
>      EXPRESSION ([symbol] = 4020)
>      STYLE
>        COLOR 255 186 54
>        SIZE 8
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Åpent område"
>      EXPRESSION ([symbol] = 4030)
>      STYLE
>        COLOR 255 221 154
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Halvåpent område"
>      EXPRESSION ([symbol] = 4040)
>      STYLE
>        COLOR 255 205 114
>      END # style
>      STYLE
>        symbol "halvapent"
>        SIZE 100
>        COLOR 255 255 255
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Vegetasjon, nedsatt løpbarhet"
>      EXPRESSION ([symbol] = 4060)
>      STYLE
>        COLOR 196 255 185
>      END # style
>    END # CLASS
>    CLASS
>      NAME "God sikt, nedsatt løpbarhet"
>      EXPRESSION ([symbol] = 4070)
>      STYLE
>        symbol "vertgreen1"
>        SIZE 84
>        COLOR 61 255 23
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Vegetasjon, dårlig løpbarhet"
>      EXPRESSION ([symbol] = 4080)
>      STYLE
>        COLOR 139 255 116
>      END # style
>    END # CLASS
>    CLASS
>      NAME "God sikt, dårlig løpbarhet"
>      EXPRESSION ([symbol] = 4090)
>      STYLE
>        symbol "vertgreen2"
>        SIZE 42
>        COLOR 61 255 23
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Vegetasjon, ikke løpbar"
>      EXPRESSION ([symbol] = 4100)
>      STYLE
>        COLOR 61 255 23
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Bygning"
>      EXPRESSION ([symbol] = 5260)
>      STYLE
>        COLOR 0 0 0
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Forbudt område"
>      EXPRESSION ([symbol] = 5270)
>      STYLE
>        COLOR 158 186 0
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Vann"
>      EXPRESSION ([symbol] = 3010 or [symbol] = 3020 )
>      STYLE
>        COLOR 0 0 255
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Plass"
>      EXPRESSION ([symbol] = 5290)
>      STYLE
>        COLOR 209 66  0
>        #COLOR 230 120 0
>        #COLOR 241 198 165
>      # COLOR 209 66 0 # Brun
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Myr"
>      EXPRESSION ([symbol] = 3100)
>      STYLE
>        COLOR 0 0 255
>        SYMBOL "marsh_isom"
>        MINSIZE 3
>        SIZE 30
>        #MAXSIZE 100
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Farlig myr"
>      EXPRESSION ([symbol] = 3090)
>      STYLE
>        COLOR 0 0 255
>        SYMBOL "farligmyr"
>        MINSIZE 3
>        SIZE 50
>        #MAXSIZE 100
>      END # style
>    END # CLASS
>    CLASS
>      NAME "Utydelig myr"
>      EXPRESSION ([symbol] = 3110)
>      STYLE
>        COLOR 0 0 255
>        SYMBOL "indistinctmarsh_isom"
>        MINSIZE 3
>        SIZE 60
>        #MAXSIZE 200
>      END # style
>    END # CLASS
>  END # LAYER # kart - polygons
>> thanks,
>> thomas
>> On Tue, Oct 13, 2009 at 10:39, Havard Tveite <havard.tveite at umb.no> wrote:
>>> Symbology change in 5.6.0?
>>> In the list of changes for 5.6.0, I have not found any mention of
>>> changes to symbol rendering.  However, from 5.4.2 to 5.6.0 beta3,
>>> many of my vector symbols (polygon fills, points, "decorated"
>>> lines) have been screwed up both for AGG and GD.
>>> Something must have changed regarding how the "bounding box" of a
>>> vector symbols is calculated when using it as tiles in a polygon
>>> fill, and when placing point symbols.  It used to always use (0,0)
>>> as the upper left corner, and the maximum x and y values as the
>>> lower right corner.  This must be different now.  See the attached
>>> images for an example of the resulting changes in rendering of
>>> polygon fills.
>>> The blue pattern that you see in the images are specified as
>>> follows in the map file (exploiting the use of 0,0 as the upper
>>> left corner):
>>> SYMBOL
>>>  NAME "marsh_isom"
>>>  TYPE vector
>>>  FILLED true
>>>  POINTS
>>>   0 0.6666666
>>>   100 0.666666
>>>   100 1
>>>   0 1
>>>   0 0.66666666
>>>  END
>>> END
>>> SYMBOL
>>>  NAME "indistinctmarsh_isom"
>>>  TYPE vector
>>>  FILLED true
>>>  POINTS
>>>   0 0.2
>>>   0.45 0.2
>>>   0.45 0.3
>>>   0 0.3
>>>   0 0.2
>>>   -99 -99
>>>   0.7 0.2
>>>   1.15 0.2
>>>   1.15 0.3
>>>   0.7 0.3
>>>   0.7 0.2
>>>   -99 -99
>>>   0.125 0.5
>>>   1.025 0.5
>>>   1.025 0.6
>>>   0.125 0.6
>>>   0.125 0.5
>>>  END
>>> END
>>> This is a significant change, in my opinion, and users should
>>> at least be warned.  Perhaps it even should wait to 6.0.
>>> I do not know the exact nature of the change, but it could make
>>> it more difficult to implement advanced vector symbols and
>>> precise vector symbol placement.
>>> In RFC 45, some of the symbology challenges and possible
>>> solutions are discussed.  The introduction of a (SYMBOL)CENTER
>>> tag could help a bit in reducing the consequences of the
>>> current change, but would not address the polygon fill problem.
>>> Should this be filed as a bug?
>>> Håvard
>>> Daniel Morissette wrote:
>>>> MapServer 5.6.0-beta3 has just been released and is available for
>>>> download
>>>> at
>>>>  http://mapserver.org/download.html OR
>>>>  http://download.osgeo.org/mapserver/mapserver-5.6.0-beta3.tar.gz
>>>> Please also keep an eye on the 5.4 to 5.6 Migration Guide where we will
>>>> document migration issues for this release:
>>>> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/MIGRATION_GUIDE.TXT
>>>> Some great progress has been made since beta2 as you can tell from the
>>>> list of fixes included at the end of this message, but there are a
>>>> couple of
>>>> tricky issues that are still being worked on, so we will have at least
>>>> one
>>>> other beta next week before we can have a release candidate.
>>>> Once again, we need your help to ensure a high quality product so please
>>>> help out by testing your applications with this new beta and reporting
>>>> your
>>>> results.
>>>> Thanks for your help
>>>> The MapServer development team.
>>>> Version 5.6.0-beta3 (2009-10-07):
>>>> - Fixed SDE layer seg fault (#3152)
>>>> - Fixed placement of labels using ANGLE AUTO which were not always
>>>> positioned
>>>>  correctly (#3160)
>>>> - Enable output of geometry in GML GetFeatureInfo if wms_geometries and
>>>>  wms_geom_type are specified (#2989)
>>>> - fix URN typo in mapwfs.c for urn:EPSG:geographicCRS:...
>>>> - don't apply scalefactor to label outlines (#3157)
>>>> - update namespaces and schema pointers (#2872)
>>>> - add RFC49 and RFC40 keywords to copy functions (#2865)
>>>> - minor fix to correct numberOfResults when maxfeatures is set in
>>>>  mapfile (#2907)
>>>> - Fixed possible crash with WFS GetFeature when no projection is
>>>> specified
>>>>  at the map level (#3129)
>>>> - Fixed anchor point of vertically stacked bar graphs
>>>> - Fixed TEXT property that cannot be removed in the CLASS object.
>>>>  PHP/Mapscript (#3063)
>>>> - Fixed use of minfeaturesize auto with curved labels (#3151)
>>>> - Fixed msRemoveHashTable function when 2 keys have the same hash
>>>> (#3146)
>>>> - Fix raster thread deadlock condition on posix/linux (#3145)
>>>> - Do not route thread debug output through msDebug which requires
>>>> locking.
>>>> - Fix WCS coverage metadata handling if size/resolution missing (#2683).
>>>> - Fix WCS crash with use of datasets that aren't physical files (#2901).
>>>> - Fix WCS failure with WCS 1.1 OGC URN (urn:ogc:def:crs:OGC::CRS84)
>>>> (#3161).
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> Håvard Tveite
>>> Department of Mathematical Sciences and Technology, UMB
>>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> Håvard Tveite
