[mapserver-dev] How to force color reduction processing without
saving to a file in mapserver library
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Oct 24 17:28:48 EDT 2009
Hi all,
I'm using the mapserver library in C to generate an image and chop it
into tiles. It is working great so far, but I have a question about
optimizing it.
Currently, I have to save the generated image to a file to force
mapserver to perform the image processing and color reduction. like:
OUTPUTFORMAT
NAME agg
DRIVER "AGG/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGB
#FORMATOPTION "INTERLACE=false"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
oImg = msDrawMap(map, MS_FALSE);
ret = msSaveImage(NULL, oImg, szMetaImg); // FORCE COLOR REDUCTION
then if loop over the image and chop it into tiles like:
msImageCopyMerge(oTile->img.gd, oImg->img.gd,
0, 0, tileLeft, tileTop, tileWidth, tileHeight, 100);
ret = msSaveImage(NULL, oTile, buf);
Like I said, this works great, but I would like to avoid doing the extra
I/O of saving the metatile, if I can just call a function to trigger the
image reduction. If I do not save the image, then the buffer is still in
24 bit RBG mode and the tiles are all black on output.
Thoughts?
-Steve W.
