[mapserver-dev] How to force color reduction processing withoutsaving to a file in mapserver library
Steve Lime Steve.Lime at dnr.state.mn.us
Mon Oct 26 19:43:19 EDT 2009
The image buffer will always be in 24 or 32 bit mode I think. You can write the image
to a in memory buffer with msSaveImageBuffer but I don't think that gets you anywhere.
You could just use GD functions after the drawMap() to reduce and chop I suppose.
Steve
>>> On 10/24/2009 at 4:28 PM, in message <4AE37190.1070907 at swoodbridge.com>,
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Hi all,
> I'm using the mapserver library in C to generate an image and chop it
> into tiles. It is working great so far, but I have a question about
> optimizing it.
> Currently, I have to save the generated image to a file to force
> mapserver to perform the image processing and color reduction. like:
>    OUTPUTFORMAT
>      NAME agg
>      DRIVER "AGG/PNG"
>      EXTENSION "png"
>      MIMETYPE "image/png"
>      IMAGEMODE RGB
>      #FORMATOPTION "INTERLACE=false"
>      FORMATOPTION "QUANTIZE_FORCE=ON"
>      FORMATOPTION "QUANTIZE_DITHER=OFF"
>      FORMATOPTION "QUANTIZE_COLORS=256"
>    END
> oImg = msDrawMap(map, MS_FALSE);
> ret = msSaveImage(NULL, oImg, szMetaImg); // FORCE COLOR REDUCTION
> then if loop over the image and chop it into tiles like:
> msImageCopyMerge(oTile->img.gd, oImg->img.gd,
>     0, 0, tileLeft, tileTop, tileWidth, tileHeight, 100);
> ret = msSaveImage(NULL, oTile, buf);
> Like I said, this works great, but I would like to avoid doing the extra
> I/O of saving the metatile, if I can just call a function to trigger the
> image reduction. If I do not save the image, then the buffer is still in
> 24 bit RBG mode and the tiles are all black on output.
> Thoughts?
> -Steve W.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
