[mapserver-dev] Vote for MapServer 5.6 release plan
Stephen Woodbridge woodbri at swoodbridge.com
Tue Sep 8 12:14:29 EDT 2009
Daniel,
I would agree with Tamas on the Work in Progress section. I think it
would be appropriate to list "Work in progress" that is targeted for 6.0
and NOT 5.6 so that it is clear to anyone reading the plan.
I also assume that the 5.0 developments are happening in sandboxes or
local copies that the developers have checked out and that those changes
are NOT flowing into 5.6 without some specific discussion and approval
to that we maintain a stable release stream. I can potentially see some
generic changes "in preparation" for at code migrating to trunk if
discussed and approved, but I think it would be your job to say yeah/nay
on that kind of change as you need to manage risk/benefit and stability
on the release.
-Steve
PS: Thank you for taking on the release manager role again.
Tamas Szekeres wrote:
> +1 to the motion with the following comments:
> I think the '/Work in progress or unknown status/' section should be
> refined a bit. I really don't know what's the current status of the
> newly added Cairo/OpenGL renderers and the XML mapfile efforts. It would
> be reasonable to add some testing steps in msautotest to make sure these
> additions are working fine on all supported platforms.
> Best regards,
> Tamas
> 2009/9/8 Daniel Morissette <dmorissette at mapgears.com
> <mailto:dmorissette at mapgears.com>>
>     Since there were no comments on the proposed release plan for 5.6,
>     let's get things going by opening the vote on it.
>     I propose that we adopt the MapServer 5.6 release plan at
>     http://trac.osgeo.org/mapserver/wiki/56ReleasePlan, with a feature
>     freeze date of September 18th, and a release date around October
>     24th, 2009, with Daniel Morissette acting as Release Manager.
>     And I start with my +1
>     Daniel
>     Daniel Morissette
>     http://www.mapgears.com/
>     _______________________________________________
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-dev
