[mapserver-dev] mapserver performance windows/linux
Dan Little
danlittle at yahoo.com
Wed Sep 16 13:36:23 EDT 2009
Are you using the same label rendering engine on both platforms (GD True-type or AGG)?
>From: JUDD.CHRISTOPHER <JUDD.CHRISTOPHER at flsenate.gov>
>To: mapserver-dev at lists.osgeo.org
>Sent: Tuesday, September 15, 2009 11:04:59 AM
>Subject: [mapserver-dev] mapserver performance windows/linux
>We have migrated our PHP Mapscript application from Windows
>to Linux. Everything appeared to be working well until we starting
>drawing maps that did quite a bit of label rendering. We found linux to
>be over twice as slow as Windows XP (running MS4W 2.3.1) on the same hardware when
>drawing labels. If I turn the labeling off, the map performance exceeds
>that of windows. I am using the same TrueType fonts on both
>systems.
>I have tried a number of different debian based
>distributions including: Debian Lenny, Xubuntu and Ubuntu Server with different
>versions of PHP Mapscript including 5.0.3, 5.2 and 5.4. All exhibited the
>same results.
>Has anyone ran into this problem? Is there something significantly
>different between the way Windows and Linux process fonts that could explain
>this?
>Thanks,
>Chris
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090916/6130f533/attachment.html
