[mapserver-dev] mapserver performance windows/linux
JUDD.CHRISTOPHER
JUDD.CHRISTOPHER at flsenate.gov
Thu Sep 17 15:08:20 EDT 2009
That is right, I did find this same performance issue with 5.0, 5.2 and
5.4 on linux.
I just tested ms4w_3.0_beta7 and it is taking about 3.7 seconds to draw
the same image that 2.3.1 did in 1.4 seconds.
Someone else should probably do the same testing to make sure that I'm
not off base.
How do I do the profiling?
Thanks for your help,
Chris
-----Original Message-----
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan
Boudreault
Sent: Thursday, September 17, 2009 2:59 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] mapserver performance windows/linux
I don't think 5.2 is faster than 5.4. He said (on IRC) that he tried
5.0, 5.2 and 5.4 with the same performance problem ONLY under Linux. I
think
the profiling is the best place to start for him.
Alan
On September 17, 2009 02:51:55 pm Stephen Woodbridge wrote:
> Jeff McKenna wrote:
> > JUDD.CHRISTOPHER wrote:
> >> I forgot to add, I'm using ms4w 2.3.1 for the windows side.
> > Since your Linux tests are with MapServer 5.4.2, then shouldn't your
> > Windows tests be with the same version? (MS4W 3.0 contains
> > 5.4.2)
> I would agree with Jeff, but if 5.2 is faster in general on the same
> platform than 5.4 for this case, then please file a bug against this,
> because I am not aware of any changes that should have impacted
> performance of LABEL ANGLE AUTO.
> Thanks,
> -Steve W
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
Mapgears
http://www.mapgears.com
