[mapserver-dev] mapserver performance windows/linux
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Sep 17 16:28:06 EDT 2009
Has anyone worked with valgrind profiling or callgrind, these tools
typically do not require that you recompile using the -pg option and may
return better profiling results. I use valgrind all the time for memory
checking, but have not use the profiling tools.
-Steve W
Andy Colson wrote:
> I dont think this is a useful profile. The program ran for 2.6 seconds,
> and this profile says msClipPolylineRect took up 100% of the time, which
> it measured 758 calls with a total time of 0.01 seconds.
> So the profiler was able to account for 0.01 of 2.6 seconds. I'm not
> sure what that means, but the numbers don't add up.
> -Andy
> JUDD.CHRISTOPHER wrote:
>> Andy,
>> That looks pretty close to the numbers that I am getting.
>> Steve, will that suffice for the profiling? I guess it would be nice to
>> look at the differences between ms4w 2.3.1 and 3 beta 7.
>> I'd like to do whatever I can to help identify this as a bug and try to
>> get it fixed.
>> Thanks,
>> Chris
>> -----Original Message-----
>> From: Andy Colson [mailto:andy at squeakycode.net] Sent: Thursday,
>> September 17, 2009 3:27 PM
>> To: JUDD.CHRISTOPHER
>> Cc: Alan Boudreault; mapserver-dev at lists.osgeo.org
>> Subject: Re: [mapserver-dev] mapserver performance windows/linux
>>> That is right, I did find this same performance issue with 5.0, 5.2
>> and
>>> 5.4 on linux.
>>> I just tested ms4w_3.0_beta7 and it is taking about 3.7 seconds to
>> draw
>>> the same image that 2.3.1 did in 1.4 seconds.
>>> Someone else should probably do the same testing to make sure that I'm
>>> not off base.
>>> How do I do the profiling?
>>> Thanks for your help,
>>> Chris
>> On Linux its easy. recompile with -pg, then run it once which will dump
>> out a gmon.out, then use the gprof to view it.
>> No idea on windows.
>> I used shp2img because I dont have php script compiled. I downloaded
>> your test set and changed the mapfile extent to match what you had in
>> the php script.
>> shp2img takes 2.6 seconds to render, and my images came out a lot like
>> yours. (I'm also using mapserver 5.6)
>> I tried it with both gd and agg and it didnt seem to make a
>> difference. But changing to ANGLE AUTO made it run in 0.8 seconds.
>> Here are my gprof dumps.
>> AGG, ANGLE FOLLOW:
>> Flat profile:
>> Each sample counts as 0.01 seconds.
>> % cumulative self self total
>> time seconds seconds calls ms/call ms/call name
>> 100.00 0.01 0.01 758 0.01 0.01 msClipPolylineRect
>> 0.00 0.01 0.00 82305 0.00 0.00 msRectOverlap
>> 0.00 0.01 0.00 67590 0.00 0.00
>> intersectLabelPolygons
>> 0.00 0.01 0.00 36963 0.00 0.00
>> msIntersectSegments
>> 0.00 0.01 0.00 32460 0.00 0.00 msGetBit
>> 0.00 0.01 0.00 16988 0.00 0.00 msSHXReadSize
>> AGG, ANGLE auto:
>> Flat profile:
>> no time accumulated
>> time seconds seconds calls Ts/call Ts/call name
>> 0.00 0.00 0.00 98521 0.00 0.00 msRectOverlap
>> 0.00 0.00 0.00 83806 0.00 0.00
>> 0.00 0.00 0.00 32460 0.00 0.00 msGetBit
>> 0.00 0.00 0.00 16988 0.00 0.00 msSHXReadSize
>> 0.00 0.00 0.00 15472 0.00 0.00 msSHXReadOffset
>> 0.00 0.00 0.00 14715 0.00 0.00 msSHPReadBounds
>> 0.00 0.00 0.00 4067 0.00 0.00 msFree
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
