[mapserver-dev] mapserver performance windows/linux
Howard Butler
hobu.inc at gmail.com
Thu Sep 17 16:52:53 EDT 2009
Shark on OS X puts to shame just about every other profiler I've ever
used.
On Sep 17, 2009, at 3:28 PM, Stephen Woodbridge wrote:
> Has anyone worked with valgrind profiling or callgrind, these tools
> typically do not require that you recompile using the -pg option and
> may return better profiling results. I use valgrind all the time for
> memory checking, but have not use the profiling tools.
> -Steve W
> Andy Colson wrote:
>> I dont think this is a useful profile. The program ran for 2.6
>> seconds, and this profile says msClipPolylineRect took up 100% of
>> the time, which it measured 758 calls with a total time of 0.01
>> seconds.
>> So the profiler was able to account for 0.01 of 2.6 seconds. I'm
>> not sure what that means, but the numbers don't add up.
>> -Andy
>> JUDD.CHRISTOPHER wrote:
>>> Andy,
>>> That looks pretty close to the numbers that I am getting. Steve,
>>> will that suffice for the profiling? I guess it would be nice to
>>> look at the differences between ms4w 2.3.1 and 3 beta 7.
>>> I'd like to do whatever I can to help identify this as a bug and
>>> try to
>>> get it fixed.
>>> Thanks,
>>> Chris
>>> -----Original Message-----
>>> From: Andy Colson [mailto:andy at squeakycode.net] Sent: Thursday,
>>> September 17, 2009 3:27 PM
>>> To: JUDD.CHRISTOPHER
>>> Cc: Alan Boudreault; mapserver-dev at lists.osgeo.org
>>> Subject: Re: [mapserver-dev] mapserver performance windows/linux
>>>> That is right, I did find this same performance issue with 5.0, 5.2
>>> and
>>>> 5.4 on linux.
>>>> I just tested ms4w_3.0_beta7 and it is taking about 3.7 seconds to
>>> draw
>>>> the same image that 2.3.1 did in 1.4 seconds.
>>>> Someone else should probably do the same testing to make sure
>>>> that I'm
>>>> not off base. How do I do the profiling?
>>>> Thanks for your help,
>>>> Chris
>>> On Linux its easy. recompile with -pg, then run it once which
>>> will dump
>>> out a gmon.out, then use the gprof to view it.
>>> No idea on windows.
>>> I used shp2img because I dont have php script compiled. I
>>> downloaded your test set and changed the mapfile extent to match
>>> what you had in the php script.
>>> shp2img takes 2.6 seconds to render, and my images came out a lot
>>> like yours. (I'm also using mapserver 5.6)
>>> I tried it with both gd and agg and it didnt seem to make a
>>> difference. But changing to ANGLE AUTO made it run in 0.8 seconds.
>>> Here are my gprof dumps.
>>> AGG, ANGLE FOLLOW:
>>> Flat profile:
>>> Each sample counts as 0.01 seconds.
>>> % cumulative self self total
>>> time seconds seconds calls ms/call ms/call name
>>> 100.00 0.01 0.01 758 0.01 0.01
>>> msClipPolylineRect
>>> 0.00 0.01 0.00 82305 0.00 0.00 msRectOverlap
>>> 0.00 0.01 0.00 67590 0.00 0.00
>>> intersectLabelPolygons
>>> 0.00 0.01 0.00 36963 0.00 0.00
>>> msIntersectSegments
>>> 0.00 0.01 0.00 32460 0.00 0.00 msGetBit
>>> 0.00 0.01 0.00 16988 0.00 0.00 msSHXReadSize
>>> AGG, ANGLE auto:
>>> Flat profile:
>>> no time accumulated
>>> time seconds seconds calls Ts/call Ts/call name
>>> 0.00 0.00 0.00 98521 0.00 0.00 msRectOverlap
>>> 0.00 0.00 0.00 83806 0.00 0.00
>>> 0.00 0.00 0.00 32460 0.00 0.00 msGetBit
>>> 0.00 0.00 0.00 16988 0.00 0.00 msSHXReadSize
>>> 0.00 0.00 0.00 15472 0.00 0.00
>>> msSHXReadOffset
>>> 0.00 0.00 0.00 14715 0.00 0.00
>>> msSHPReadBounds
>>> 0.00 0.00 0.00 4067 0.00 0.00 msFree
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
